Global Motorsports Group proudly releases its 1.8t Big Turbo Kit.
Old 03-09-2008, 11:38 AM
Former Vendor
Global Motorsports's Avatar
Default Global Motorsports Group proudly releases its 1.8t Big Turbo Kit.
<img src="http://pictureposter.audiworld.com/64565/fk_pics_113.jpg">
<img src="http://pictureposter.audiworld.com/64565/fk_pics_114.jpg">
GMG World Challenge BT 1.8t Kit Specs:
With much success over the last year, we have finished two 1.8t Turbo Kits of our own that have proven to be both powerful and reliable on a daily basis.
Garrett GT28xx Turbocharger (Options Below)
GT28RS
GT2871R
GT2876R
GMG Mandrel Bent Tubular Exhaust Manifold
GIAC 91 Octane Performance Software
GMG Mandrel Bent Downpipe
GMG Billet Forged Diverter Valve
GMG Turbo Hot Side Heat Shield
GMG Coilpack Heat Shield
GMG Heat Shielded Cold Air Intake
GMG Oil and Coolant Feed/Return Lines
All Turbo Hardware/Fittings/Seals
Siemens High Flow Injectors
Bosch High Flow Fuel Pump
Bosch Increased Diameter Mass Air Flow Housing
Lower Compression Head Gasket (.7 Compression Drop)
On to what you all want to see, Dyno Plots.
Pump gas with a built 2.0t Motor 370HP @ 6500RPM
Race gas with a built 2.0t Motor 490HP @ 6600RPM
*GT2876
Larger turbos (such as GT30+) will produce more power*
*More dyno plots with a 1.8t to follow*
<img src="http://giacusa.com/images/018pbt_100vs91vsstock.jpg">
Big thanks go out to GIAC for all of their hard work and tuning to help get this car to where it is today!
Old 03-09-2008, 01:11 PM
maxh2o's Avatar
pricing set yet?
Old 03-09-2008, 03:03 PM
Guest
VR_Life's Avatar
Default Looks nice - and the GT2871 is a perfect fit for the 1.8T - but I'd be worried about longevity
Three cheers for doing a nice a/m turbo kit and s/w - that's not easy, I know.
However it appears from the photo that the Compressor Intake and Compressor Outlet pipes have been TIG welded the onto the turbo, which is <b>NOT</b> a very good idea. It's very likely that will crack after a few K mi's.
Keeping in mind the weight of downpipe and exhaust are hanging directly off the Turbo, while the engine itself pitches about the axis of the drive shaft - yet the intake &amp; Intercooler assembly is bolted onto the car frame. You need to keep the mass that vibrates to an absolute min. and isolate it from the parts that don't move, using flexible couplings.
2~4 ply Silicone couplers and Constant Torque Clamps are the preferred solution.
Also, I cannot see a brace from the top of the Head to the Turbo. Vibration will eventually destroy those welds on the tubular EM first. Tubular EM's are notorious for their short lifespan on the track, using this setup on the street is likely to lead to metal failure which is ingested by the turbine, destroying the turbo - BTDT !
Of course getting a replacement GT28R turbo will be a PIA since yours effectively has a custom housing.
Refer to the following books for backup and the math involved on these exact issues:
<a href="http://www.amazon.com/Induction-Performance-Practical-Supercharging-Turbocharging/dp/1859606911/ref=pd_bbs_sr_1?ie=UTF8&s=books&qid=1205103495&sr= 8-1">Forced Induction</a>
<a href="http://www.amazon.com/Maximum-Boost-Turbocharger-Engineering-Performance/dp/0837601606/ref=pd_bbs_3?ie=UTF8&s=books&qid=1205103495&sr=8-3">Maximum Boost</a>
Both of these books are widely considered the bible of Turbos, by professionals in the industry.
Cmmartin23
26
08-23-2016 04:44 PM
Turguin
Audi A3 / S3 / RS 3 MKII
09-12-2015 02:48 PM
ECS Tuning-Audi
09-08-2015 11:47 AM
ECS Tuning-Audi
09-08-2015 10:42 AM
Quick Reply: Global Motorsports Group proudly releases its 1.8t Big Turbo Kit.
