Tahoe: question on snow chains
Old 02-12-2007, 12:08 PM
New Member
mimeme's Avatar
Default Tahoe: question on snow chains
In the (few) times I've been up to Tahoe, having a FWD, I've taken chains along. Now I have an A4 quattro, would I need either chains or snow tires ? If I do, which one should I get ? I don't plan to go there more than 6 times for the whole of winter.Sorry if this is an FAQ, I did search the archives.
Old 02-12-2007, 12:15 PM
Member
Audi-Sav's Avatar
No chains..use either all seasons or snows.
Old 02-12-2007, 12:45 PM
Member
Crapple0's Avatar
Default chains can damage your quattro
furthermore, it's unlikely you'll have enough suspension member clearance to install chains
get either all-season tires, or another set of rims with snow tires (can be found on craigslist for as little as $400)
Old 02-12-2007, 12:50 PM
im_cecil's Avatar
Default At a minimum, get all season M+S tires, but true winters are MUCH better. Carry chains in the car,
but you'll never use them. They don't even have to fit, but you might be asked to show them.<ul><li><a href="https://forums.audiworld.com/other/msgs/3425870.phtml">CHP road conditions, from da archives.</a></li></ul>
Old 02-12-2007, 12:51 PM
Audiboy's Avatar
Default Get all seasons, but carry chains just to pass an inspection if it happens.
Unless you are in back country, you typically will not encounter road conditions by Caltrans that need chains on 4wd with all season or M+S tires.
Old 02-12-2007, 01:43 PM
Sin4lly's Avatar
Default I was up this past wkd w/all seasons. Did just fine since the roads were not too thick w/snow.
didn't take it to the resorts though since my car is too low. Would've ate up a whole lotta snow. If you hit up the resorts when it's sunny, nothing to worry about w/all seasons. See the pics I posted a few posts down,
Old 02-12-2007, 02:08 PM
Member
Crapple0's Avatar
Default pff...my car is as low as yours and i was fine
i hit a bit of snow with my exhaust, i think, but hot exhaust on wet snow = like buttah
Old 02-12-2007, 02:34 PM
L8TE APX's Avatar
Default Just completed a 2 week ski trip incl Sierra's, Utah, and Colorado in an Avant
Pirelli P Zero Nero M&amp;S. Was waived through every chain required location and had no problems the whole trip. At times 4-6 inches of snow on the road and tempatures as low as 6 degrees. You do not need chains and your owners manual tells you not to use them.
Old 02-12-2007, 04:58 PM
New Member
mimeme's Avatar
Default Re: Tahoe: question on snow chains
Thanks a lot for the advice!
Old 02-12-2007, 05:28 PM
Sin4lly's Avatar
Default I would've had 3 passengers, 2 fat ones :-). The parking lots must've had 8" or more of slush
Glad your car made out ok.
Quick Reply: Tahoe: question on snow chains
