Go Back   AudiWorld Forums > Community Discussion > Off-topic Discussion
Register Forgot Password?
How can I thaw a frozen PVC pipe quickly? My sump line to the outside froze up at the end....
LinkBack Thread Tools Search this Thread Display Modes
Old 12-22-2008, 03:33 PM   #1
Elder Member
Account #: 25336
Default How can I thaw a frozen PVC pipe quickly? My sump line to the outside froze up at the end....
hence backing up the sump, motor died, bla bla bla.
Got a new sump, got some heat tape, but have to thaw the end of the pipe out which the heat tape is not doing. Any suggestions?
The one time in my life I wish I had a squirt gun to fire hot water down the pipe to loosen it up.
AIM: bonaturtle
1988 Porsche 911 Coupe
2003 Kymco People 50
2007 Mazda3 HB GTS
Follow me on RTW Trip: http://bit.ly/Zu3Iy
The Turtle is offline   Reply With Quote
Old 12-22-2008, 03:36 PM   #2
Member
Account #: 109028
Default is the pipe all exposed or buried?
PaulKemp is offline   Reply With Quote
Old 12-22-2008, 03:36 PM   #3
Account #: 20822
Default heat blanket?
Charlie in SoCal
Audi gone bye-bye
Mr T dont take no jibba jabba
ECP SCORE 247, CARBON OUTPUT 7 tons
khukwgn is offline   Reply With Quote
Old 12-22-2008, 03:37 PM   #4
Elder Member
Account #: 25336
Default all exposed except for the 6 inches inside the wall going to the outside...
i'm guessing the blockage is in that area.
AIM: bonaturtle
2007 Mazda3 HB GTS
Old 12-22-2008, 03:37 PM   #5
Elder Member
Account #: 25336
Default I might try that next, and a hair dryer for the outside so it gets heat from both sides
AIM: bonaturtle
2007 Mazda3 HB GTS
Old 12-22-2008, 03:41 PM   #6
Member
Account #: 109028
Default I'd just aim a space heater at it, heat up the foundation wall, pipe, everything
don't catch your house on fire... but if you do, take pics for us.
I'd even drag another space heater outside and duck tape a plastic tent around it.
sounds like a fun project. happy holidays.
Old 12-22-2008, 03:44 PM   #7
Elder Member
Account #: 25336
Default yeah, don't live at this property, so no go on that, maybe the pressure of the new injector pump...
will force it out, who knows.
AIM: bonaturtle
2007 Mazda3 HB GTS
Old 12-22-2008, 03:47 PM   #8
Member
Account #: 19359
Default aluminum foil + blow torch
Connect with me:
wnut is offline   Reply With Quote
Old 12-22-2008, 03:47 PM   #9
Member
Account #: 19359
Default or pay some fat broad on cL to give it a tit job.
Connect with me:
Old 12-22-2008, 03:55 PM   #10
Member
Account #: 92383
Default Thats gonna be a bear to fix. Maybe add some antifreeze to the sump pit too?
08 White Rabbit
Retired:
2000 A4 2.8 30v w\Tip & Pearl
1988 90 2.0 8v w\3spd & Pearl
Audi, VW, Porsche ETKA access (updated)
Keyless Chuck is offline   Reply With Quote
Old 12-22-2008, 04:08 PM   #11
Account #: 27563
Default Attach a garden hose to the drain on your HW heater.
You know what you did.
Audi Junkie is offline   Reply With Quote
Old 12-22-2008, 04:26 PM   #12
Account #: 3018
Default Good call....I like the idea.
Larry H is offline   Reply With Quote
Old 12-22-2008, 05:04 PM   #13
Senior Member
Account #: 48672
Default Not sure of your layout, but up here when things freeze hard- we blast heat at it
<center><img src="http://blogs.aviation.ca/media/wf2.jpg"></center><p>1. Seal the area to contain the heat where you want it to go.
2. Then we get one of these: A Herman Nelson type jet heater. All our rental shops have them - then again we deal with this much more often.
3. Anyway, light this fella up, aim it correctly away from ignitable materials, (after you have made a test run in open space and learned how it operates safely)
4. your water problem will be flowing soon.
Be fire smart and have an extinguisher standing by too!
YukonAudi
83 4000S Turbo Diesel
90 Coupe quattro 20v
Quattro: Because for every mile of road - there's two miles of ditch.
YukonAudi is offline   Reply With Quote
Old 12-22-2008, 06:56 PM   #14
Elder Member
Account #: 25336
Default gonna try a heat blanket and hair dryer, i figure 5 minutes of each at either end will melt it fast
AIM: bonaturtle
2007 Mazda3 HB GTS
Old 12-22-2008, 06:56 PM   #15
Elder Member
Account #: 25336
Default I would do that, but this is small area that is stuck, and I don't live there
AIM: bonaturtle
2007 Mazda3 HB GTS
Old 12-22-2008, 08:54 PM   #16
Account #: 27563
Default Thank you. Overkill always works.
AudiWorld
Audi R8
Paid Advertisement
Tags
27t, antifreeze, frozen, line, lines, location, outdoor, pcv, pipe, pipes, pvc, sump, thaw, thawing, unthawing
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Join AudiWorld
Copyright 2014 AudiWorld.com Audi Enthusiast Community
