Go Back   AudiWorld Forums > Community Discussion > Off-topic Discussion
Register Forgot Password?
Polycarbonate (Luxottica/LensCrafters 'FeatherWate') lenses -- fact or fiction?
LinkBack Thread Tools Search this Thread Display Modes
Old 06-06-2001, 05:31 AM   #1
Junior Member
Account #: 88
Default Polycarbonate (Luxottica/LensCrafters 'FeatherWate') lenses -- fact or fiction?
I bought a couple of new pairs of glasses on Monday from Luxottica/LensCrafters. The first was a pair of prescription Ray-Bans, and they used traditional plastic lenses. They turned out fine.
However, I picked up another pair of lightweight frames using polycarbonate ('FeatherWate(tm)')lenses. They feel much better, and getting used to them was very easy because they were essentially the same shape and size (but not weight or thickness) as my old frames.
BUT...
The polycarbonate lenses, while clear at the tops and center, seem to provide refraction on the left and right edges, and at the bottom (where it's worst.) That is, there is a blue edge to the bottom of dark objects, and a red edge to the top of them. It's very slight and I believe most people would believe that the prescription was defective. I'm not sure if it's that or the material.
When I tried to describe what was occurring in scientific terms to one of the sales gimps at LensCrafters, she was thoroughly confused (she didn't know what 'refraction' meant) She claimed that it was the material and that I would 'get used to it.' However, I'm not really satisfied with the prospect of lenses that provide a lack of clarity, however minor.
As I said, it's only on the left and right edges, and at the bottom--that is, the peripheral areas of the lens (not to be confused with peripheral vision.) It's more noticable at the bottom.
Any comments?
Audi Car Club, Chicagoland Chapter,
http://www.audichicago.org/
2000 Audi S4M (B5)
2003 Volkswagen Passat GLS 1.8T (B5.5)
2007 Volkswagen Passat 2.0T (PQ46)
CobaltJacket is offline   Reply With Quote
Old 06-06-2001, 05:41 AM   #2
Member
Account #: 14
Default Did you have them check the lenses?
I've had a prescription done once, and they didn't bother to check.
In my case, the lens was defective with a very noticeable wave in it.
I have the Featherwate(sp?) lenses and I don't notice any such qualities in my glasses. Since
they have equipment to verify the quality and prescription of the lens...I'd have them check it.
-Alex L.
99.5 1.8TQT Santorin Blue
alian is offline   Reply With Quote
Old 06-06-2001, 05:44 AM   #3
Junior Member
Account #: 88
Default They checked them and supposedly they match my old glasses
My old glasses are made of plastic, but don't have any refraction problems. My prescription apparently hasn't changed.
2000 Audi S4M (B5)
Old 06-06-2001, 06:18 AM   #4
Junior Member
Account #: 88
Default Text I sent to LensCrafters website
I sent this to their Customer Service group:
Hello,
I purchased two pairs of glasses from your Woodfield (Schaumburg, Illinois) store on Monday, June 4th, 2001.
The first pair was a pair of prescription sunglasses using plastic lenses. Those turned out to be fine.
The second pair were FeatherWate frames with the polycarbonate lenses.
I have noticed that on the edges and bottom of the polycarbonate lenses, there is a slight prism effect occurring. This is especially noticable for dark objects--at the bottom of the lens, the top of the object will have a red edge, and the bottom will have a blue edge. On the left part of the lens, the left side of the object will be blue, the right side will be red, and so on.
While the effect is slight, it is annoying, to say the least. It means that in order to view the object with absolute clarity, I must actually turn my head. It becomes exacerbated during reading--when one tends to keep their head in a uniform position and simply move their eyes to scan the page (or screen, since I use computers on a daily basis.)
Bear in mind that the optometrist at Woodfield (Dr. Robert E. Peachey) conducted my eye exam and compared it to my previous prescription (purchased at Pearle), and stated that there had been no change in 4 years. My old prescription, as well as the LensCrafters prescription sunglasses (manufactured at the same time) do not display this effect.
In any event, I went to the LensCrafters in Butterfield Plaza in Downers Grove, IL, yesterday. The sales lady compared my old lenses and the new polycarbonate lenses and pronounced them identical except for the material. She claimed that the difference was, indeed, due to the material and that I would adapt over time. She also stated that I could get the lenses re-milled in plastic if I desired.
However, it is my belief that there is no way to adapt to an optical effect of this nature (prisming,) and that it is either a problem with the material, or with the way the lenses were milled. I cannot fathom the reasoning that it is the material--would Luxottica SpA actually sell lenses where this effect occurred? Wouldn't more people be complaining?
Please respond.
2000 Audi S4M (B5)
Old 06-06-2001, 06:35 AM   #5
Account #: 900
Default Different lens materials have different refractive properties.
Glass is the best but even different types of glass have different properties from each other. Considering the markup on glasses, LensCrafters should exchange them for regular plastic if you want to.
PabloX is offline   Reply With Quote
Old 06-06-2001, 06:52 AM   #6
Junior Member
Account #: 88
Default Yeah, but should I accept prisming? I'm really just trying to determine whether this is common...
2000 Audi S4M (B5)
Old 06-06-2001, 08:12 AM   #7
Account #: 900
Default You should really run it by them.
Some people are more sensitive to such things than others. I once got a pair of prescription poly carb sunglasses. They got the optical center slightly off and they drove me nuts.
Ask them if this is common with polycarb. If it is or isn't, they should take them back if you don't like them. Alternatively, go to another place and say you're interested in a new pair of glasses and have heard about problems with polycarb. The lenses themselves may just be ground wrong.
Old 06-06-2001, 09:15 AM   #8
Account #: 525
Default Same effect on my polycarb lenses - 10+yrs, different fabs, different docs
I think it's a combination of high power prescriptions and high index of refraction materials. My glasses are backups to contacts, so the color shift doesn't bother me much.
Richard
'14 S6 4.0TQDSG
'01 A6 2.7TQM - Sold
"Turbos make torque, and torque makes fun." -Corky Bell
Please help get PDF manuals from AoA by supporting http://www.audipdfpetition.org
Richard Solomon is offline   Reply With Quote
Old 06-06-2001, 10:46 AM   #9
Junior Member
Account #: 88
Default Maybe, but my prescription isn't all that high powered
2000 Audi S4M (B5)
Old 06-06-2001, 02:15 PM   #10
Account #: 749
Default Polycarbonate lenses have a very narrow field and...
...THEY SUCK. I got talked into polycarbonate lenses once, about 7 years ago. In two days I was back at Lenscrafters, and made them remake me a pair of normal materials. They had to eat the first pair.
They never told me that the focal field would be so narrow. I like larger lenses, so it was very apparent. Once I got 15 degrees off the optical centers of the lens, it got fuzzy and diffracted. I told them, politely, to stick'em where the sun don't shine.
I didn't get much of an argument. I wouldn't have accepted it, anyway. As they are dispensing a medical device. they're very dependant on licensing. A suggestion of a phone call to your State's medical regulatory agencies will move mountains, if it comes to that.
John/TSR is offline   Reply With Quote
Old 06-08-2001, 11:54 PM   #11
Account #: 474
Default It is a function of high index lenses...
I wear "regular" glasses with high index lenses -- 1.66. After a few years with no problems, I only recently realized that they split light when I look through the lenses off-center.
It usually isn't bad, but when I look at bright light it is more annoying.
I spoke with my opthamologist and also my optician about it, and they both agree that high index lenses refract light more than the thicker, lower index lenses, hence a higher degree of chromatic abberation around the edges. Pretty basic optics, actually, and I am surprised that I never realized it before about my glasses.
I am finally ordering new glasses with a slightly lower index (1.60 instead of 1.66) to minimize on the chromatic aberration. Any lower than that, and my glasses will be too thick.
But back to your question, Lenscrafters is the worst of all the chain optical shops. I won't even go into my ordeal with them. Long story short, they could not make me a pair of glasses after three tries. They must know that they are pretty bad, because they refunded my money without any issues.
-- Peter
New car: 2006 B7 A4 2.0TQMS, Prem, Tech, OceanBlue
Sold:
1998.5 B5 A4 1.8T Quattro Sport
Sept. 11, 2001 -- We will not forget.
UrA4 -- 1998.5 1.8tqms
GIAC 1 bar, APR exhaust, Turbo5 BPV, Neuspeed shifter, OEM Sport springs, Bilstein Sport shocks, AWE-DTS
AWE VDO Nightvision Boost gauge, Euro projectors, Philips HID, Alpine V12 MRV-F357, DLS Sub, Focal 130K
Oettinger RE 17x8, Toyo T1-R 225/45-17, ECS Tuning Stage II Brakes
Pelican Pete is offline   Reply With Quote
Old 10-27-2014, 04:53 PM   #12
Account #: 292720
Default LENSCRAFTERS - Avoid this chain!
Think twice before dealing with LensCrafters
I escelated the matter via my BBB complaint and then had input from David Bauer at HQ and it was agreed that LensCrafters would make up just one lens. (dbauer@luxotticaretail.com Rx Operations Manager (678) 472-8481)
On Sat. 10/26 I returned to the Kennesaw location and had extensive discussions with the Manager and an Associate regarding a price issue. I had been told on 10/17 that the cost for 2 lenses would be $110. On the 26th I was told that they would, as per their HQ make up one lens and the cost would be $110! My opinion was that the cost should be in the area of $55-60 or half what they had wanted for making up 2. They would not agree to this and decided to take my contact info and contact HQ for further instructions. It is now a 'don't call us - we'll call you situation' as they will supposedly contact HQ for guidance. I am still waiting to hear from them!
Their treatment of a returning customer who had last year purchased 3 pair of lenses and glasses from them and had been impressed enough to tell the manager of that time that the associate helping him had done a great job, tells me that this firm has absolutely no concern about customers and no desire to encourage customer loyalty to their brand. They seem to exist entirely for what goes into their cash register that business day and never mind any long term concepts of taking care of 'old' customers or encouraging future visits, they are just interested in how much $ they can wring out of customers that day.
I have since determined that there is great dis-satisfaction with consumers regarding this firm, with 447 complaints to the BBB over 3 years and 96 complaints on the site Ripoff Report | Scams, reviews, complaints, lawsuits and frauds. File a report, post your review. Consumers educating consumers. I have established 8 blog sites in anticipation of additional nonsense from LensCrafters and they will 'go active' if/when LensCrafters HQ decides that it is just fine for them to attempt to charge $110 for the one lens. Here is a link of one of those sites FYI: LensCrafters Sucks!
Misc. I see from my sitemeters that LensCrafters HQ in Mason, Ohio IP Address: Luxottica (66.161.213.180) has been looking at my site 5 times in the last 2 days. I hope they learn something from my comments. As things stand now they have a very poor reputation and have some really stupid corporate policies.
Here are my existing blog sites FYI, this weekend I will be adding another 20+:
Screw Lenscrafters
KENNESAW LENSCRAFTERS SUCKS
LensCrafters Sucks!
Avoid Lens Crafters
Avoid LensCrafters!
If you spend 1 cent at LensCrafters you are a moron.
Wm Inkennesaw is offline   Reply With Quote
AudiWorld
Audi R8
Paid Advertisement
Tags
abberation, blurry, chromatic, exchange, featherwate, featherwates, glasses, high, index, kind, lenscrafters, lenses, making, marks, polycarbonate, store, suck, thick
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Join AudiWorld
Copyright 2014 AudiWorld.com Audi Enthusiast Community
