Go Back   AudiWorld Forums > Community Discussion > Off-topic Discussion
Register Forgot Password?
The shift lock on an Automatic Jetta won't let the car out of park (yes the brake is pressed).
LinkBack Thread Tools Search this Thread Display Modes
Old 10-19-2006, 03:54 PM   #1
Account #: 27909
Default The shift lock on an Automatic Jetta won't let the car out of park (yes the brake is pressed).
<center><img src="http://static.worldnow.com/nctd/images/cars/02jetta-4.jpg"></center><p>
Where is the manual override to release the shift lock on a Jetta?
Dustin A4 is offline   Reply With Quote
Old 10-19-2006, 03:56 PM   #2
Account #: 30439
Default Was it parked on a hill? The torque converter could be locked up -- if so you need someone
to push the car in the opposite load direction to take the strain off.
im_cecil is offline   Reply With Quote
Old 10-19-2006, 03:57 PM   #3
Account #: 90994
Default the brake pedal switch/sensor might be loose or disconnected. try putting it in neutral before
you start it, that's what I had to do with my old car when that happened. The switch tells the computer that you have the brake depressed and can shift the car out of park
|sig|
EPL Custom Tune w/ OEM RS6 Turbos.
"I wish I could have a stage 3 car to be disapointed in. :-)" - IBG 2007-01-16 16:15:26
RIP O.W. Kenobi
|/sig|
wagongotya is offline   Reply With Quote
Old 10-19-2006, 03:59 PM   #4
Account #: 27909
Default Tried that, but it won't let the car into D or R. Every time you restart the car it locks.
Old 10-19-2006, 03:59 PM   #5
Elder Member
Account #: 70341
Default Maybe a problem with the ignition?
Baraqyal is offline   Reply With Quote
Old 10-19-2006, 04:00 PM   #6
Account #: 80383
Default Did you check the ignition switch?
Speed doesn't kill... its the sudden stop that kills.
washparkS4 is offline   Reply With Quote
Old 10-19-2006, 04:00 PM   #7
Account #: 27909
Default I am 90% sure pedal switch/sensor... is there a manual override to get it moving?
That way he can drive to the dealership and get it fixed. Otherwise it needs to be towed.
More $$$ (out of warr)
Old 10-19-2006, 04:01 PM   #8
Account #: 90994
Default srsly, check the switch on the brake pedal (up at the top of the pedal arm)
|sig|
RIP O.W. Kenobi
|/sig|
Old 10-19-2006, 04:02 PM   #9
Account #: 27909
Default Starts, stops, runs fine, and the wheel turns. I think it's the sensor on the brake.
Old 10-19-2006, 04:03 PM   #10
Account #: 27909
Default If the switch is broke it will need replaced. Looking for a temp workaround to drive it.
AudiWorld
Audi R8
Paid Advertisement
Tags
2000, 2001, 2007, 2008, a4, automatic, brake, control, jetta, lock, manual, override, park, problems, release, shift, volkswagen
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Join AudiWorld
Copyright 2014 AudiWorld.com Audi Enthusiast Community
