Go Back   AudiWorld Forums > Community Discussion > Off-topic Discussion
Register Forgot Password?
Why do tires scallop/cup on inside or outside edge? Alignment or balance. Which one's the culprit?
LinkBack Thread Tools Search this Thread Display Modes
Old 11-22-2002, 12:24 PM   #1
Senior Member
Account #: 29942
Default Why do tires scallop/cup on inside or outside edge? Alignment or balance. Which one's the culprit?
Both of my fronts are cupping on the inside edge. Independent shop did an alignment, I wasn't happy and they gave me a refund. My ****ty-*** Nissan dealer can't do alignments on 18s so they are useless.
akediord is offline   Reply With Quote
Old 11-22-2002, 12:27 PM   #2
Account #: 27673
Default alignment
too much camber if i remember correctly? toe, if not.
thermonuclear is offline   Reply With Quote
Old 11-22-2002, 12:38 PM   #3
AudiWorld Expert
Account #: 36175
Default This might help you.
My guess is they are probably scalloped and it is due to to much toe-out. toe-in would wear on the outside edge.<ul><li><a href="http://www.metropark.com/safewaytire/tireware.html">http://www.metropark.com/safewaytire/tireware.html</a</li></ul>
Current:
2004 S4
No Warranty:
66K Fuel filter $45
67K Motor mount $200
67K Coil pack(s) $40*2
67K Window regulator $100
71K Battery $135
2003 TT 1.8T
No Warranty:
50K Hazard Switch $50
Past:
1998 A4 1.8TQMS
B6/7 S4 Hawk Pad part number update!
Should no longer need to do the below anymore:
How to modify C5 A6 Hawk pads for use in the B6/B7 S4 or B7 A4
S4iowa is offline   Reply With Quote
Old 11-22-2002, 12:39 PM   #4
AudiWorld Uber User
Account #: 13879
Default Why are you getting an alignment already?
Evilclown is offline   Reply With Quote
Old 11-22-2002, 12:42 PM   #5
Member
Account #: 10901
Default if it's feathered across the tire then, inside = toe out, outside = toe in. more tire info. -->
If it's just the edge then, inside = too much neg. camber and outside = pos. camber, which is rare and I'm not sure that you could with an Audi. It would have to be way out of spec.
go to the alignment section:<ul><li><a href="http://www.discounttiredirect.com/right_help.html">http://www.discounttiredirect.com/right_help.html</a</li></ul>
-Jeff
2001.5 A4 1.8TQMSCC with APR SIII, EVO FMIC, Stoptech-less, STaSIS Tracksports 600F/750R
ACNA MidOhio video
Montreal race school and PDA Pocono video
Silver Streakin' is offline   Reply With Quote
Old 11-22-2002, 12:47 PM   #6
Account #: 12690
Default Could also be bad/worn tie rod ends.
Andy_FL is offline   Reply With Quote
Old 11-22-2002, 12:50 PM   #7
AudiWorld Uber User
Account #: 13879
Default On a brand new Z?
Old 11-22-2002, 01:03 PM   #8
Senior Member
Account #: 29942
Default Excellent. Thanks!
Old 11-22-2002, 01:04 PM   #9
Senior Member
Account #: 29942
Default Thanks!
Old 11-22-2002, 01:05 PM   #10
Senior Member
Account #: 29942
Default Because it was pulling to the right just a bit. Seems to afflict a lot of Zs...
and I was trying to do something about it.
AudiWorld
Audi R8
Paid Advertisement
Tags
alignment, cup, cupping, edge, inside, makes, oustide, race, rare, rear, scallop, scalloped, scalloping, scallops, tire, tires
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Join AudiWorld
Copyright 2014 AudiWorld.com Audi Enthusiast Community
