Interior LED Kit + Exterior LEDs-Error Free-Lifetime Warranty-Free shipping
Audiworld Basic Sponsor
---------------------------------------------LEDs------For------Your-------Audi----------------------------------------------------------------
CHECK OUT OUR NEW AUDI SECTION ON OUR WEBSITE!!!!!
CLICK HERE for all Updated LEDs for your Audi Car - updated with new LEDs weekly!
Our LEDs are PLUG AND PLAY / ERROR FREE
**PLEASE NOTE** IF you do not see your model listed, contact us and we will work on SPECIAL PRICING to make you a custom set, if you help us test and review a NEW Audi LED Kit it will be FREE!!
Features of our LEDs:
-The lights will "fade out" when you turn off your car just like your current stock lights
-These will not stay on or “glow” after you shut off your car like other sets
-Crisp White color – No cheap blue or yellow tint
-Works with MFD (car controls)
-No Errors
-Lifetime Warranty
-No footwell spotting like other inferior LED sets
Interior LED Kits:
LEDs for Audi ? deAutoKey
License Plate LEDs:
Check out our Universal LED bulbs For Audi License Plates:
Universal License Plate LEDs Super Bright / Error Free Fits many VW and Audi Models ? deAutoKey
-Compatible with-
Audi MKII TT
Audi B5 A4
Audi B5 S4
Audi A3 8P
Audi A4 B6 B7
And our Complete LED Housing Audi License Plates:
LED License Plate Housings Crisp White-Error Free-Plug and play Fits: Many Audi Models ? deAutoKey
-Compatible with-
A3/S3 O4-09
A3 Cabriolet 08-09
B6 A4/S4 01-05
B7 A4/S4 05-08
A6/C6 05-09
S6 05-09
D3 A8/S8 03-07
Q7 07-09
RS4 Avant Quattro 06-08
RS4 Carbriolet 06-08
RS6 Avant 08-09
Before & After:
Same bulbs for sale are being used in cars below:
*NEW*LED FOOTWELLS:
New & the first!!
Footwell Option for Audi models equipped with OEM LED footwells!
Choose from Crisp White / Red or Blue!!
New LED Footwells for Audi models that are equipped with OEM LED Footwells ? deAutoKey
If you have non-LED Footwells, please follow link below:
2pc 6 LED Wafer Footwell set in Crisp White/Red/Blue fits: VW, Audi, all cars ? deAutoKey
*NEW*TRUNK LED Strip - Brightest option ever:
Get the brightest LED for your trunk with no hassle at our low introductory price. [THIS FITS ALL CAR MODELS]
To purchase:
Universal 48 LED Flexible Strip for your Trunk [Fits all Car Models] ? deAutoKey
We did the research, and created the best and brightest LED for your trunk, our 48 LED Strip simply lines your trunk, with either 3m tape or velcro which are both included.
This is the best solution for a dark trunk, easily installs and hides:
-Plug & Play
-Error Free
-48 Bright White LEDs (Also comes in red)
-Enough LEDs to light up your entire trunk but short enough to fit any trunk, can install vertically or horizontally.
-Long wire, that is an all stealthy black which allows for an easier clean install, this wire is long enough to place anywhere in your trunk
-Strong 3M tape & Velcro so you can install on any hard surface or trunk lining (please use a blow dryer to heat up glue and cold metal, this will activate the glue)
-Resistor which allows for the light to stay on and not dim if your dome lights shut off while trunk is open. This feature is a must have, it allows for a bright continuous light at all times.
-Trunk LED will not stay dimly lit when your car is off.
-Comes with 3 adapters: Wedge, Adjustable Festoon, and Bayonet, this will fit every trunk adapter on the market.
Actual LED strip measures: 31 inches – this length will fit all trunks, can install vertically or horizontally.
Black Wire measures: 52 inches – please note- excess wire simply tucks into your trunk’s housing/lining so you will not have any leftover in your trunk.
Includes:
1 LED strip with strong 3M tape attached
3 Adapters (Wedge/festoon/bayonet)
3 Pieces of velcro
-No Errors
-Lifetime Warranty
Interior LED Kits:
License Plate LEDs:
-Compatible with-
Audi MKII TT
Audi B5 A4
Audi B5 S4
Audi A3 8P
Audi A4 B6 B7
-Compatible with-
A3/S3 O4-09
A3 Cabriolet 08-09
B6 A4/S4 01-05
B7 A4/S4 05-08
A6/C6 05-09
S6 05-09
D3 A8/S8 03-07
Q7 07-09
RS6 Avant 08-09
Before & After:
*NEW*LED FOOTWELLS:
New & the first!!
To purchase:
-Plug & Play
-Error Free
Includes:
3 Pieces of velcro
w:http://deAutoKey.com
-Error Free LEDs for your Audi (interior & exterior)
f: https://www.facebook.com/deAutoKey
i: http://instagram.com/deAutoLED
Amazing review of our error free BRIGHT Reverse LEDs:
194 10pc CREE LED Reverse LED Fits:Audi A3/S3/RS3 + Many More | deAutoKey
Ok all, here is the write up on the DeAutoLED rear LED reverse lights vs stock & the license plate LEDs.
The overall assessment on the reverse lights is get'em. Totally worth it. Brighter by far. I can actually see in my rear camera now. Night and day (pun intended) difference.
The License plate lights, well, they don't fit. The actual piece looks nice, and I'm sure it's brighter, but they aren't plug & play with the Audi wiring. They sent a wire adapter with them, but it does not fit the Audi wiring either, and to be honest, the small end plug that fits into the light housing itself is pretty flimsy. Not a solid click in like the OEM one. I'd recommend skipping these, as I am sending mine back.
So here goes the install on the reverse lights. Easy Peazy. Trim tools required and one Phillips head screwdriver. Reference above link I put in my thread for a video.
Before
Drivers side (Left) LED/ Passenger (Right) OEM bulb
Both side LEDs
Close up OEM Bulb
Close up LED
Install
Pop the square bumper plate with plastic trim tool
Use Phillips screwdriver to loosen retaining screw
Pop the reflector/light housing out of the bumper with plastic trim tool
Locate the ballast for the reverse light. Rotate it, take it out, and remove OEM bulb.
Before
Both side LEDs
Close up OEM Bulb
Close up LED
Install
Check out license plate LEDs for all Audi models:
Exterior Lighting - License Plate LEDs | deAutoKey
Our LEDs are a clean crisp white - place it next to your current License plate to see the difference!
Happy New Year!
Thank you for a great year!
Turn Signals:
We have a NEW line-up of BRIGHT BRIGHT BRIGHT Error Free Front turn Signals!
Due to variations it is best to look up what bulb you have either by:
-Looking in your owner’s manual
-Looking at the model on the bulb itself
-Bulb guide:
Bulb/LED Guide & Help | deAutoKey
Check them out!
PWY24W:
New Amber or White PWY24W Front Turn Siganls Error Free Bright Fits: Most Audi Models | deAutoKey
H16/PSY24W
Front Turn Signals H16 PSY24W Error Free fits: Most Audi Models | deAutoKey
PH24WY
New Front Turn Signals PHY24W Error Free fits: Most Audi Models | deAutoKey
bau15s:
NEW Rear Turn Signal OSRAM 3 Tower LED Bulb Fits: Volkswagen 08 Touareg | deAutoKey
-Bulb guide:
Check them out!
PWY24W:
H16/PSY24W
PH24WY
bau15s:
10% off: “PR10”
15% off $175+ Purchase: “PR15”
20% off $275+ Purchase: “PR20”
25% off $475+ Purchase: “PR25”
Attachment 105109
Attachment 105109
Thanks for the support - email us at anytime if you need any help finding the right LED for your car:
Support@deAutoLED.com
White/Yellow/Halogen/Strobe/Flash plug and play fogs:
Dual Color LED Fog [1 bulb 2 colors] Choose between a Clean White & Hyper 3000k Yellow at anytime | deAutoLED
-Plug and play
-Error free in most cars. Some might need extra resistance - we sell a new design that DOES NOT require you to attach it to metal. It is compact and easy to install - simply plug into OEM adapter and our LEDs (100% plug and play NO splicing design)
-Easy to switch between each color – simply turn OEM fog switch off/on - normal cycle: White - yellow - halogen - flash/strobe
-BRIGHT – this is not just a novelty bulb
-COLOR MATCH - these match our LEDs/HIDs in 5500K White mode
-HYPER YELLOW - these are a true hyper yellow mode you normally see with yellow lamin-x covering the lens **this is NOT a cover around a bulb or a cover on your lens - this is brand new LEDs that are a super hyper 3K yellow**
-SAFE – more light on the sides and down the road when dark or in bad weather conditions
-The Hyper Strobe / Flash – this does not simply "flash" but has a strobe/flash pattern like an emergency vehicle - you can choose between 4 different modes - video of mode 1:
https://www.youtube.com/watch?v=T-fex4DUPSg
3 colors:
-Super Hyper 3000K Yellow that many like for bad weather: Rain, snow, fog
-Clean White 5500k that matches our LED & HID Headlights
-Halogen 4300k that matches OEM
Video cycling quickly through colors AND different strobe/flash features:
https://www.youtube.com/watch?v=bQG0gRKGFk0
INFO:
-THESE ARE BRIGHT! You might have seen the novelty fog LEDs that can turn yellow/white on amazon and ebay by the thousand that don't provide much useful light, trigger errors, die quickly, or simply don't work correctly. Our new model fixes every issue you might've seen and simply works.
-These produce MORE LUMENS than many standalone single color white fog LEDs on the market
-Not only are these great for safety, daily use on dark roads and bad weather this will amaze at any car show and you will have your friend asking how did you do that and where can I get those anytime you use these fogs!
*Please note these ARE error free but in strobe/flash mode they can trigger an error in some car models – errors WILL clear once you go back to a solid color.
Attachment 104952
Attachment 104953
UPDATED FAQ
Is there a lifetime warranty?
YES! As always this comes with a True Lifetime Warranty!
Will your fogs keep changing colors if you use them as cornering lights?
The answer is no as this only changes by turning your fog switch on/off. If you are using your fogs as cornering lights it will always be the default color of white.
How does this work with the coming home feature?
This works just like OEM. It will always be the default color of white.
What if I have the yellow feature on and turn off my car; will it then go into the next color when I turn it back on?
The LEDs will always revert back to the default color of white. Then simply turn the fog on/off for your desired color: yellow/halogen or strobe/flash mode.
Can these turn 360 degrees?
Yes, these are a fully adjustable design so you can turn these 360 for the best beam angle.
Are these as bright as your single color de360 fogs?
While not as bright lumen wise it comes very close - many people that have switched to our single color white to our dual color yellow/white LED fog kit have not noticed any difference in visibility. As we said this is NOT a novelty yellow/white you normally see. This is meant to be used to help with your visibility.
Can you bypass the strobe feature?
Yes, this works when you turn the fogs on/off quickly. If your next mode will be strobe simply shut off the fogs for a few seconds and then turn it back on and it will go back to the default white.
Attachment 105060
Attachment 105061
Attachment 105062
Attachment 105063
Some more fun shots - in the rain:
Attachment 104954
White / the super hyper yellow - this will be a hyper lamin-x yellow without the cover!
Attachment 104955
Attachment 104956
And switch back to clean white:
Attachment 104957
-Plug and play
3 colors:
INFO:
Attachment 104952
Attachment 104953
UPDATED FAQ
Attachment 105060
Attachment 105061
Attachment 105062
Attachment 105063
Attachment 104954
Attachment 104955
Attachment 104956
Attachment 104957
