'14 Q5 TDI shifts to neutral at stop light
My '14 Q5 TDI-21,850 miles-will intermittently drop from drive to neutral while waiting at a stop light. Have to shift the car to neutral then back to drive before tranny will work. Any ideas?? Thanks- David
Q5 Transmission problem
yes, engine revs & no car movement- no warning lights. The start stop mode is engaged, sometimes the engine is off & sometimes not.- thanks
Q5 TDI Transmission shifts to neutral @ stop light
yes, auto start-stop is engaged during this time, sometimes motor is running & sometimes not. Ill try driving with the start-stop off & see what happens. Service check sched for monday, thanks. DRR
Let me know what your dealer does, mine has been at the dealer for 2 weeks now for that issue.
I went to the dealer & the service tech said to drive & watch it. With no warning light or fault codes there is nothing they can do. So I'll fly it & watch it for now.- David R
Audi service tech said since there are no fault lights or codes, all I should do is drive it & see what happens, it still occurs about twice a week, always at a stop sign. I've tried "start stop on & off- still the same. I slide the shift lever to neutral & back to drive, then it works. No brake needed.- David 11-27-'15
