2013-16 A/C software upgrade service advisory issued
Received this today.
Does anybody know "exactly" what the software change does?
I sounds like the electric auxiliary air heater PTC heating element is degrading, and just guessing the software update will either limit the time that it is on, or lower the voltage
applied to it. My aux heater works just fine in the winter so I'm reluctant to have any changes done to it until I find out what those changes are.
Looks like Audi QC just continues to go down. An electric heating element should have a lot of QC life cycling performed on going by the element supplier to prevent issues like this.
Sounds most peculiar, Bob.
I can't see how a software update would prevent "degradation" of a heating element. Unless, perhaps, Audi is being clever again and a computer is interactively applying power to the heating element. And the original software literally overpowers the element, causing it to burn out prematurely?
An hour long software update....I'll bet someone is still using a 1200 baud modem.(G)
My 2014 2.0T has a MMI entry for this heater but I thought that it was only for diesels with their long and slow warm up.
the same 1200 baud modem they use to update the NAV maps.
Sorry it's also in other Q5's. I get great heat coming out of the vents within 200 feet of starting and instantly driving the Q5 even with an ambient temp of zero degrees F.
complain that the heating element quit working, Audi would say see there's still some warmth coming out of the vents at startup!!!! Also to replace the heating element requires nearly removing the entire dash!!!
Audi does not want to do that.
I say that this is Heater-gate, and we should all get buy backs..................
Apparently the Audi Transmogrifier only knows how to translate "modifier" words as "auxiliary". So, the diesel's heating unit, is "auxiliary" heater. The gasoline "I can't wait" heater, same "auxiliary".
Heck, they even have us believing the Q5 is a car, not a truck, while they simultaneously swear to the government that it is a truck, not a car.
Since they (supposedly) had to replace my climate control computer, not just reprogram it, in order to stop it from icing up? I have to wonder what half of "have to replace" I misunderstood.
But again, this could be very similar to old-fashioned flashlight bulbs. Some even used 6v tractor headlights and ran them at 9 volts, which cut the service life intentionally from 30 hours to 3 hours, but increased the brightness something like ten-fold at the same time. Plenty of room in between to pick a compromise point that is still "bright". Could be someone just found that dropping the heat by ten degrees, doubled the life of the element. Or, prevented some solder or epoxy from failing.
We'll never know unless we take hostages. You know, if you feed German engineers and executives enough wurst and lager, and confine them to a Morris Mini Minor for a couple of days...hehheh. Waterboarding becomes an improvement in life, doesn't it?
Diesel-powered models currently have an electrical
PTC element, although a pre-heater is optional.
Vehicles equipped with an optional pre-heater also
have a PTC heater element as an auxiliary heater at
start of production. The "fuel powered" pre-heater is
currently not used as an auxiliary heater in these
vehicles.
Sounds like "make it not fail within the factory warranty period" software change. I would like an extended warranty for the 3 years it took Audi to figure this out.
The pre heater in gas Audi's showed up with the ability to run E85 in flex fuel vehicles. Very challenging to generate heat quickly with E85 in cold weather so the pre heater was added.
