2013 Audi Q5 2.0T oil consumption - Page 3 - AudiWorld Forums
Go Back   AudiWorld Forums > Audi Models > Audi Q3 /Q5 / Q7 > Q5/SQ5 Discussion
Log In
Q5/SQ5 Discussion Discussion forum for the Audi Q5 SUV
Sponsored by: Audi
LinkBack Thread Tools Search this Thread
Old 06-30-2013, 01:34 PM   #21
2013-06-30 (current)
4,400km (half according to MMI)
refilled 3/4 quart of 5w40 at 3,200km..
2013 audi q5 2.0t..
it's burning at a rate of 0.25 quart per 900km.
2013 Audi Q5 2.0 TFSI Premium Plus (Daytona Grey) + S line Sport Select Package + NAV with 19" wheels & Black Seats/Dashboard & Lunar Silver Headliner.
pkalltheway2000 is offline   Reply With Quote
Old 06-30-2013, 04:13 PM   #22
2013 audi q5 2.0t..
I have 3500 miles on my 2013 Q5 2.0T and MMI still shows full.
123Audi4me is offline   Reply With Quote
Old 06-30-2013, 04:58 PM   #23
Quote:
that's the part i don't understand, how come some 2013 2.0t burn oil and some don't?
i find that the engine burns more oil if driving mostly in stop and go (city driving)....somehow i find it doesn't burn as much when driving long distance...
this is from my observation as i have just finished a 800km road trip in two days, it was at 3/4 full at all times...as soon as i came back and started driving in city for the past two days, it dropped a quart to half...
Old 06-30-2013, 06:44 PM   #24
Senior Member
Default Reasons, and things to check more:
The oil may not be getting burned in the old conventional sense of getting past the piston rings, or alternately past the valve stem seals. The rings would be the really worrisome ones since it requires a full engine tear down/replace. The stem seals are not insignificant, but are within the (removable) cylinder head. The classic checks for these are blue smoke out the exhaust on decent acceleration suggests rings (usually only seen on pretty tired motors), and blue smoke seen during long coast downs (like off a long down sloped highway offramp or down a long downward grade with foot off gas pedal) suggests valve stem seals. Both tend to tie to very high mileage or abused motors.
But rather than either of these, most likely what is happening is oil vapor is getting sucked through the PCV system and then burned in the engine. This is also an issue secondarily with the FSI motors since it later gets connected to fouled intake valves from the oil crud that gets deposited there and cooked onto the valves. Your hoped for fix/improvement to reduce oil consumption generally (if it persists) would be the basic PCV valve that regulates the vapor flow with vacuum, so the motor doesn't just suck too much in without giving the vapor a chance to settle back to regular (fluid) oil. The part name varies by motor some, but that's the conceptual component. You may want to search the archives more--whether here or in the even higher volume A4 boards with the 2.0T about it.
Finally, yes it does not surprise me you see it more in the city, and it's really a further sign excessive vapor is being pulled. Motors are at their highest vacuum at idle, during coast down and just off idle, at lowest under full acceleration, and at moderate levels cruising. Hence with lots of stop and go in town, the percentage of time the motor is running at high vacuum is much higher. In this case too, it's really motor run time that matters, not miles, so not nearly as many miles in town as on the highway per hour of run time translates to what you are seeing as more consumption per mile with renewed city driving.
Current #1: '06 D3 A8L W12 brilliant black w/ amaretto; 4 seat setup, CPO; modestly lowered, H&R 20mm rear and 12mm front DRs with 275/35 on OEM polished + forged 20's; S8 sway bars (see: rear bar and gen'l D3 bar info and front bar); tweaked 385mm front factory brake mod and matching rear brake mod; matching C6 A6 back headrests (better rear view: headrest tweak); owner installed AMI retrofit with part number details here. [pics now only in picture poster] Upper control arm reference (+ more info in replies) here. Lower cost D3 OES sway bar links here.
Current #2: 2013 Q5 2.0T hybrid; Scuba blue w/ chestnut sport interior; Euro delivery 7/2013 (pictured at Ingolstadt); RS5 front brakes
Prior (each modded): 2000 C5 A6 4.2 & '96 C4 A6 2.8Q, both still w/ family; '85 C3 5000S 5 sp FWD; '73 C1 100LS
helpful cross reference to C6 MMI and various other TSB's that also cover D3 A8's.
MP4.2+6.0 is offline   Reply With Quote
Old 07-01-2013, 12:24 AM   #25
I have been told by the dealer that the oil consumption is due to the use of low tension piston rings - the low tension rings are used to reduce friction and improve fuel efficiency. The design counts on the compression ring being pushed down into its seating by the high pressure gas within the cylinder to seal properly. If the engine is at low throttle, the seal becomes less effective, so there is more blow-by, resulting in more oil vapour being sucked out of the PCV. That's why the oil consumption issue is more pronounced in city driving, and it is less of an issue in Germany where they do a lot of autobahn driving. Basically if you drive the car harder, it will burn less oil.
tigerking is offline   Reply With Quote
Old 07-01-2013, 05:15 AM   #26
Same for me - at 4100 miles
oltmannd is offline   Reply With Quote
Old 07-01-2013, 06:00 AM   #27
With 4,200 miles down about 15%-20%. The reading varies a bit now and then.
Q5 Bob is offline   Reply With Quote
Similar Threads
Thread Thread Starter Forum Replies Last Post
2009 TFSI engine oil change Help please sssmasss Audi A3 / S3 / RS3 11 10-07-2015 04:13 PM
Shelby Monsoon Enough (break-in and other questions) Monsoonenough S4 (B8 Platform) Discussion 3 10-03-2015 03:59 PM
OEM Exhaust Tips for the 2.0T Buckwheat2088 Q5/SQ5 Discussion 0 09-28-2015 07:26 PM
Audi A3 haldex oil change DIY beep-beep Audi A3 / S3 / RS3 0 09-24-2015 03:25 PM
:: ECS Tuning :: B7 A4 2.0T ECS RA4 Conversion Clutch Kits ECS Tuning-Audi A4 (B7 Platform) Discussion 0 09-24-2015 01:06 PM
Tags
20, 2013, 20t, a4, audi, burn, consumption, hissing, motor, oil, q5, sound, tfsi, type, usage
Trackbacks are On
Pingbacks are On
Refbacks are On
