'14 TDI Malfunction + Fault Codes
Hi all,
Been lurking on here for some time now, just had my first set of issues and was wondering if anyone else has experienced anything like this.
Did some searches and came up with nothing useful.
I was just coasting down a neighborhood hill @ 25mph when the car started beeping and flashing the flashers in rapid succession (faster than if you just turned on the flashers.) I pulled over, turned off the car, and nothing changed - beeping and flashing continued at speed.
I drove the rest of the way home, parked, locked the car, and the flashers continued.
I unlocked, started up, turned off, locked again and the flashing finally stopped.
Enter the VAG-COM (Before anyone asks, it's genuine rosstech...) fault codes. My research turned up everything from F350's to TDI Jettas.
I have not tried taking the car back out - I will try a little later tonight to see if anything goes wrong.
Has anyone had any of these codes/any experience like this?
Any help would be greatly appreciated.
Address 01: Engine (J623-CPNB) Labels: 059-907-311-CLA.clb
Part No SW: 8K5 907 401 J HW: 4G0 907 401 E
Component: 3.0TDI EDC17 H14 0003
3 Faults Found:
18660 - Start interruption due to insufficient engine speed
P151D 00 [032] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
9647 - Reductant Injector Valve (Bank 1)
P208E 00 [096] - Stuck Closed
Freeze Frame:
20191 - NOx Sensor 2 Bank 1
P229F 00 [096] - Implausible Signal
Freeze Frame:
Readiness: 0 0 0 0 0
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8R0 907 468 N HW: 8R0 907 468 C
Component: GW-BEM 4CAN-M H11 0060
1 Fault Found:
00384 - Optical Databus
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 123
Mileage: 38791 km
Time Indication: 0
Date: 2015.06.20
Time: 10:53:15
Freeze Frame:
Bin. Bits: 10000
Voltage: 12.40 V
Count: 9
Bin. Bits: 00000
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 8R1 035 746 E HW: 8R1 035 746 D
Component: H-BNT-NA H41 0756
1 Fault Found:
02067 - Optical Databus; Unpermitted Wake-Up Request
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 123
Mileage: 38791 km
Time Indication: 0
Date: 2015.06.20
Time: 10:52:11
Freeze Frame:
Voltage: 12.20 V
3 Faults Found:
P151D 00 [032] - -
Freeze Frame:
Freeze Frame:
Freeze Frame:
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 123
Mileage: 38791 km
Time Indication: 0
Date: 2015.06.20
Time: 10:53:15
Freeze Frame:
Bin. Bits: 10000
Voltage: 12.40 V
Count: 9
Bin. Bits: 00000
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 123
Mileage: 38791 km
Time Indication: 0
Date: 2015.06.20
Time: 10:52:11
Freeze Frame:
Voltage: 12.20 V
cameltrophyallroad
Audi allroad
02-14-2016 07:18 PM
mdkv5
A6 (C7 Platform) Discussion
09-16-2015 01:09 AM
