2013 Q5 subwoofer upgrade
Hey guys, I drive a 2013 Q5 with the B&O upgrade.
I want to replace the stock sub in the car but I want to do it in a way where it doesn't take up any of the current trunk space. I think my best option would be to remove the stock sub and slide something in that is the same size.
What I want to know is what is the size of the stock sub? and do you guys have any recommendations on anything i could fit in the current size?
appreciate the help!
And exactly because it IS fitted into the spare tire assembly/bracket, it's not that easy to replace. Definitely DIY or do research into some of the other solutions on this board.
If you want some inspiration, give this Cayenne install a look. The Q5 is fairly similar, with the space saver, inflatable spare tire.
Hat tip to the incredible guys @ Simplicity In Sound in Cali for this install.
Cayenne SQ - Simplicity In Sound
AudiWorld Expert
The next easy thing to do would be to add a powered sub that will fit under the trunk floor, in the area in front of your spare (by removing the plastic storage tray that's in there). Something like this would work:
Sound Ordnance B-8PTD 125-watt compact powered subwoofer at Crutchfield.com
It still only uses an 8" woofer, so the bass isn't going to be earth shattering, but there is only so much you can do if you absolutely don't want to take up any trunk space.
I was considering adding this SO sub to my wife's Q5, but after hearing the stock system (non-B&O), the bass is actually not that bad. Either that, or my ears aren't as discriminating as they once were. In any case, I'm just leaving it as is.
