2014 headlight adjust???help
XTROYDX
Hi
I have a 2014 sq5 and just had kw V2 installed ... not my headlights are extremely low.. and need to know how or what I should do to fix this?
to give you an idea the level of headlights. when I turn my fog lights on , it about the same distance out. : (
Yep, just close your garage door and turn the vertical adjuster until they raise by an inch or so. I was going to do the procedure as described above but my next door neighbor (Audi mechanic) came out and told me to put away my blue tape, tape measure and cardboard to block one headlight. He hoped in my car, pulled it in the garage and eyeballed it. Then he drove it around the block, came back and adjusted once more and it was done. Maybe 5 minutes total time. He said that usually 1.5 inches at 3 ft to take them back to normal after lowering them.
XTROYDX
Thank you ,, I will give it a try, thought I was gonna have to buy a vagcom to do this...
XTROYDX
sweet.. will try it.
Judge
06-24-2008 08:50 PM
