2014 Q5 TDI First Oil change issues
#11
Reading Bob Petruska's details about the oil level sensor...wouldn't it have been easier and maybe cheaper, for Audi just to equip ALL the engines with a simple mechanical dipstick? My 2.0t Q5 has the sensor and came with no dipstick...I bought one within days, checked it against the sensor and now use it exclusively.
#12
Tim, I'm with you. Would save a lot of needless headaches.
Tdifan, 059115611AM is indeed the right part number. <EDIT: NO IT'S NOT. Read later posts in thread.> On your calibrate question, I had to do so because I got the wrong one. VW dealer in Hamburg "assured me" it was the right one, but that's old news now. I had to build up the end near the handle so the stick would stop in the proper place. "Calibrated" it by intentionally shorting the oil a half liter during an oil change, then verifying MMI (eventually) read correctly. Someday, I'll end up getting the "AM" version. In your case, as long as you're 100% sure you got the right version, it's a non-issue for you.
So this gets back to the whole, "If Audi would just put a dipstick in all their vehicles..." discussion. Grrr...
#13
According to my order from ECS - I did get the AM one.
Engine Oil Dipstick - Mfg Part#059115611AM
I am just attaching a link to the discussion here when I was in search for one.
https://www.audiworld.com/forums/q5-...2860423/page2/
Thanks!
Millen
Thanks!
Millen
#15
Funny that you asked . It did - yesterday. MMI is still confused as of the oil level though . It's still thinking and calculating. No level to display yet. And as Mr. Bob advised, I am not touching the hood. Still waiting for the friendly service manager to call me, as promised.
#16
Reason is most people don't check oil with dip sticks...
#17
Oh well, this story hopefully will end. After a trip to the dealer - i was told the dipstick is too long. So, the tech who did thee oil change, went by dipstick measure and not by the MMI . This time, they did add oil and now the MMI reads full and the above described dipstick reads "above Max".
I will appreciate any input. Should I "calibrate" the dipstick by marking the level now? Or is thete a "real" dipstick for Q5 3.0 TDI. Sarajevo friend, please step in .
Thanks!
Thanks!
#19
My Q5 is a 2014 TDI Premium Plus. The car has 3700 miles and has not yet had its first oil change. I purchased oil dipstick 059 115 611 AM from ECS last week. The MMI oil level indicator shows a level midway from MAX to MIN. I'm thinking this is a good time to compare the reading on the MMI with the dipstick. I inserted/removed the dipstick and it indicates an oil level above the MAX line (about 20 mm above the MAX line). So - either this part number (059 115 611 AM) is not the correct part for the 2014 Q5 TDI or both tidfan and I received dipsticks that were incorrectly made and are to long.
