2016 TDI QUESTION
2016 TDI QUESTION
Hi all,
Quick question, finally took wife out in Audi to get her used to it before our trip down south and all went reasonably well. However, after a short drive out the highway at legal speeds (or lower) we arrived home after maybe 20 miles and parked in the driveway. Temps this morning around 23 degrees C so not hot.
But here is the strange part, the motor cooling fans came on and are quite loud and strong. The part that bothers me is it stayed on for about 10 minutes! What the hell is that for? It didn't do this last August. The car has about 6k on it and has had its first service so all should be good.
No dash indication that it's doing it regeneration thing with the pollution system. And the temperature gauge is in normal range. What's it going to do in Texas, Florida heat?
Is this normal?
Thanks in advance.
Is this normal?
Thanks in advance.
Most likely a regeneration in process. I don't think you can worry about that.
Thanks have been reading about it fron TDI FORUMS. You are likely right. One question, isn't the dash light supposed to come on when this happens? I saw no such light, hence my query. But sure a lot of heat produced from the action!
My 2014 A6 TDI does the same thing
Sounds like the particulate filter running a regeneration cycle. Ambient temperature is immaterial. It does it when it needs to. Never saw any indicator lights on the dash while the cycles in progress.
No, no lights will appear (lights are pretty much reserved for warnings/errors, and as regen is a standard process there's nothing to warn anyone about -- the only related light you'd see the the "DPF full" warning, which you definitely don't want to see for a long time!). The fan will be on up front, there'll be a lot of heat coming from under the car (I usually feel it when I'm getting out), and there may be a "burning" smell.
Thanks for all the good replies, good to know. One last question, as my wife was driving for thr first time, I did notice anything unusual until she stopped the car we got out and heard the loud fan noises. Did screw anything up by stopping the car? Will it restart or somehow complete its cycle with the engine shut off?
Inquiring minds want to know! I apologize in advance for my ignorance.
Cheers
Cheers
Cheers
Cheers
