55K service & Performance Boost
Old 07-22-2014, 05:03 PM
mhousealum's Avatar
Default 55K service & Performance Boost
So I had the dealer print off the list of items covered in the 55k service and took it to an Indy to service. Cost was $455 vs. $610 at the dealer. Anyways, the main items in the service were spark plug change, engine air filter, and cabin air filter and a bunch of check this and check that. So I got the Q5 (2010 3.2L) back last Saturday afternoon and immediately noticed acceleration was noticeably improved. A google search pretty much stated you shouldn't notice performance increase from a spark plug change, just better starts (particularly cold weather) which wasn't a problem for me. I'm just curious what you guys/gals think and if performance increase is related to spark plug change, maybe 55k is too long to wait. I actually had just under 52k when I had the service performed. Thoughts?
Old 07-22-2014, 05:14 PM
Transfer's Avatar
I think you can notice improvement with plugs and filter changes. It might be all placebo, but I felt improvement in my M3 after that type of service.
Old 07-22-2014, 08:47 PM
mhousealum's Avatar
I agree...initial thought was placebo but the key is I had no expectations of any improvement. After 4 days I'm positive it's accelerating better. Still not sure if the plugs or filter are the cause but I'm happy with it.
Old 07-23-2014, 03:42 AM
Eryeal's Avatar
Pretty sure this kind of thing is a placebo effect. You aren't looking for a noticeable change in acceleration until the service is performed, and because of that, you think there's a change when really there isn't. I mean, even if there was a small positive change, which is much more likely - it would be too small to actually be "noticeable" .. Imagine if you were driving identical two cars - one had 300 HP, one had 305 HP - you aren't going to be able to detect the difference yourself.
Old 07-23-2014, 03:51 AM
uberwgn's Avatar
It's likely that you are enjoying a benefit from fresh plugs. Not sure why Audi calls for them to be changed at 55k miles. Maybe DI is harder on plugs. Many cars go to 100k miles today on their first set.
My B8 A4 calls for plugs at 35k miles. I changed them out already and they looked pretty good. Didn't notice much change one way or the other.
Old 07-23-2014, 07:32 AM
-hef-'s Avatar
I don't think anything he did would provide a noticeable increase in performance. Only thing I can think of is that he disconnected your battery during the service, which in turn reset your ECU. When that happens, all the learned driving patterns were deleted. So if you drive like an old lady, all that memory of 'i drive slowly/carefully' got dumped and you were back to factory spec, which feels faster.
Old 07-23-2014, 01:03 PM
mhousealum's Avatar
That's something I didn't think of....I bought the car at 28k so not sure how they drove before me. I'm going to ask him. Thx
Old 07-23-2014, 01:04 PM
mhousealum's Avatar
Again, I wasn't expecting anything related to acceleration increase. It is definitely there at the low end and even the mid-range. I drove the car since December, 2012 and I def know how it drove. Again, I'm not complaining just trying to figure out why it has improved. It's not a placebo.
Old 07-23-2014, 01:47 PM
- B -'s Avatar
It could be that the air filter was really gunk'd up with dirt...plus new plugs and your actually efficiently breathing and firing again, which makes any acceleration more pronounced...
You may want to check and make sure you have an actual new air filter in the air box, just in case the Indy mechanic forgot the air filter completely, which would make acceleration very noticeable, but also very dangerous.....at least I would if the change in acceleration is a huge change....
Old 07-23-2014, 02:14 PM
Dalancroft's Avatar
Tires that were under inflated, fouled plugs, clogged air filter, and yes perhaps an ECU remapping would, after service, make any car feel more sprightly.
ad2330
RS4 (B7 Platform) Discussion
08-01-2011 01:23 PM
Chris.Ranch
NorCal Discussion
04-26-2007 09:08 AM
The Turtle
Chicago Discussion
03-04-2004 11:32 AM
BaysideRS4
01-07-2004 09:17 AM
AmishA4T
02-12-2002 05:16 PM
Quick Reply: 55K service & Performance Boost
