ABS miscoded Fault???
Here is the VCDS fault
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 8R0 907 379 AK HW: 8R0 907 379 AK
Component: ESP8 quattro H09 0080
Revision: -------- Serial number: --------------
Coding: 151D18
Shop #: WSC 06335 000 00000
VCID: 09195174A035EA6939E-805C
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 215
Mileage: 79852 km
Time Indication: 0
Date: 2015.03.06
Time: 16:26:25
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x47A2
Hex Value: 0x0015
Hex Value: 0x1097
Hex Value: 0x0000
Coding: 151D18
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 215
Mileage: 79852 km
Time Indication: 0
Date: 2015.03.06
Time: 16:26:25
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x47A2
Hex Value: 0x0015
Hex Value: 0x1097
Hex Value: 0x0000
Coding: 151D18
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 215
Mileage: 79852 km
Time Indication: 0
Date: 2015.03.06
Time: 16:26:25
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x47A2
Hex Value: 0x0015
Hex Value: 0x1097
Hex Value: 0x0000
Coding: 151D18
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 215
Mileage: 79852 km
Time Indication: 0
Date: 2015.03.06
Time: 16:26:25
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x47A2
Hex Value: 0x0015
Hex Value: 0x1097
Hex Value: 0x0000
Thanks
One mod I did was trick the car into thinking I had the module for changing to comfort/dynamic to try to improve the steering. I changed it back as I fixed that issue by disabling the steering assist. Could that be the issue? If someone that also did this mod could scan to see if they have this issue???
In the folder ROSSTECH / VCDS / Debug / you have CodingLog.TXT and AdpLog.TXT
ABS module has nothing to do with ADS ( Audi Drive Select)
If continue on error, go in Audi service, do not play with ABS
