Any q5 with timing chain?
#21
#22
It broke around 120,000km on the highway, valves hit the pistons, engine needed a new head. Luckily I was still under CPO warranty and after a bit of argueing, VW paid for it. (5000$ :P)
Interference engines should have a timing chain IMO.
#24
Six Quebec winters would be my guess. Tensioner and pulley were fine, I remember they put a new belt on to check if the engine was ok.
I guess the problem wasn't so much having a belt, but the stupid VW maintenance that didn't require a replacement before 160,000km. Should be 100,000km max.
#26
I used to replace them between 60-75K miles, but then again my car hardly ever faced weather below 32F (0C) and "lived" in a garage most of it's life. As Kris mentioned, the condition of the idler/tensioners and adjacent parts also has a significant impact on the longevity of the belt.
#27
response to chains vs. belts
You silly. A chain never breaks. The tensioner might, MIGHT have to be adjusted every 100K. I'll take the chain as opposed to changing the rubber belt, tensioner etc. every 60-80K miles.
You also have to consider why Audi/VW switched over to steel chains (finally) about 6 years ago.
#28
Especially since this topic is 4 years old
Audi uses a timing belt on the 2.0TDI engines, while the 2.0 TFSI / 3.0TFSI engine uses a timing chain.
So your information that Audi only uses the chain is incorrect
#29
Not to mention is patently wrong. Timing chains may not break, but they most certainly "stretch", which is widely known to cause issues in a variety of Audi engines. Tensioners fail, guides fail, all too common. There is no way to "adjust" a tensioner, you have to pull covers off of the engine, and REPLACE the chains and tensioners, and guides.
Unlike a timing belt system, timing chains are not designed to be changed easily, to the point where on the V engines, the chains are at the REAR of the engine, requiring removal of the engine or transmission to service them. IT's a ridiculously bad design made worse by bean counters specifying the cheapest parts possible.
The following 2 users liked this post by Kris Hansen:
Just_Westy (10-27-2020),
spijun (06-17-2020)
gk1
05-21-2002 01:50 PM
