Low oil pressure, switch off engine
Old 05-07-2014, 10:22 AM
Theresa Wagner's Avatar
Default Low oil pressure, switch off engine
I am having trouble with low oil pressure. The dealer thinks its the oil level sensor and oil pressure switch. They had the car for over 24 hours and performed all sorts of diagnostics. They said they are 95% sure its the sensors and that would be the cheapest alternative. It is just recently out of warranty, ugh. Does anyone have this issue and I wonder if anyone actually blew the engine or if its just some sort of nuisance alarm.
Old 05-07-2014, 11:30 AM
Prospeeder's Avatar
All they have to do is check oil pressure. If its good, then they need to ground the wire from the sensor and if the light never comes on then the sensor is bad. If it does come on still theres a wiring or instrument cluster problem. What engine is in this Q5 u have.
Kokar (04-16-2022)
Old 05-09-2014, 05:46 AM
I have a 2012 Q5 Quattro 2.0. The car is still in the shop. They took it for a test drive after they replaced the pressure switch and sensor but the check engine light came on again. Now they are saying its the bleed valve, which is located on top of the engine.
alh3010
11-01-2013 01:21 AM
rxr2
1.8T Discussion
02-17-2011 01:51 AM
namjachoi
04-13-2009 09:30 AM
JMP_S4_92
Audi Original "S" Cars
07-18-2008 07:37 PM
KF8TY-Barry
08-25-2000 03:31 AM
Quick Reply: Low oil pressure, switch off engine
