Brake Pads Warning Light - AudiWorld Forums
Go Back   AudiWorld Forums > Audi Models > Audi Q3 /Q5 / Q7 > Q5/SQ5 Discussion
Log In
Q5/SQ5 Discussion Discussion forum for the Audi Q5 SUV
Sponsored by: Audi
LinkBack Thread Tools Search this Thread
Old 10-09-2011, 12:02 PM   #1
ben_aip's Avatar
Default Brake Pads Warning Light
Need help or advise from fellow forum members:
I had my 40000km (25k miles) service done 2 weeks ago. Brake pads reported to be 5mm front & 7mm rear, remaining. Service adviser said the front should be good for another 3000 to 4000km. I placed an online order last week for Centric Posi-Quiet and Power-Slotted Rotors last week, but won't be here till another 7 to 10 days (customs clearance, etc). Brake pads warning light came on last night, barely 1000 km after that service report. I need to travel over the Rockies on Wed for a business trip to Alberta(>2500km to & fro).
Questions:
- When that pad worn light shows, APPROX how far can one continue driving safely before pads replacement? (I know depending on one's driving and terrain), but how much 'meat' are normally left on OEM pads, upon light on?
- Could it be a false warning, as I'm not expecting this to occur till maybe another 2000 to 3000 km from 5mm thickness, unless it was not measured right at service 2 weeks ago.
- Understanding my dilemma - must drive situation + new pads and rotors on it way in; am I crazy to want to take the risk and make this trip first then fix it when I'm back in town.
Thanks one and all.
Current - 2014 S7 Oolong Grey, Black interior w/Fine Ash Wood Inlay; All options except B&O
Traded - 2012 A7 3.0T CdnPP, Glacier White, S-Line, Black interior w/Brushed Alum trims,
Traded -2010 Q5 3.2 Premium+ - Stratos Blue / NAV / B&O
Lease returned 2007 BMW 335i Coupe
Lease returned 2002 Volvo S40 Wagon
Sold - 1999 Merc E320 4-Matic
Sold - 1991 Volvo 744 Turbo
ben_aip is offline   Reply With Quote
Old 10-09-2011, 01:14 PM   #2
Only the front brakes have low pad warnings, Unless our Q5's are different than the past. I would just put only auto parts pads on the fronts before your long trip just to be safe. No VCDS needed for that only to install the rears later. Only around town would be no big deal because you are damaging rotors you are tossing anyway, but a long trip with hills could get more exciting than you need. On my previous Audi's when the light shows you are now on metal.
2016 A3 Cabriolet Glacier White 2.0T
2011 Q5 Ibis White 2.0T
2008 A4 Cabriolet Ibis White 2.0TQS (Sold)
2000 A4 Laser Red 1.8TQM (sold)
rdA4WtQ5 is offline   Reply With Quote
Old 10-09-2011, 01:54 PM   #3
The light is usually illuminated at 3mm of pad life. They probably measured the outer pad, where the inner is usually worn first. Id say youre ok for a week or two. Honestly, some people have gone 3-4k on the light, they did alot of highway mileage. Its not a good thing, but its not like youre metal on metal.Dont go hard on the brakes, try not to really heat them up. Since the materials gone they heat up alot quicker, they also have a lower ability to release the heat. If you hear grinding, get them done immediatley
Audi0s is offline   Reply With Quote
Old 10-09-2011, 10:52 PM   #4
ben_aip's Avatar
Quote:
Yes, only the front have low pads sensors. I did thought about getting aftermarket auto parts pads for the front just to make the trip, but not too sure if anyone carries these to fit our Q5. Will make a few calls on Tues, coz this is our Canadian Thanksgiving long weekend.
Quote:
I think you're right - they must have measured only the pads. But if anyone else on the forum can concur that they've gone at least 3k on the light, before replacement, I'd feel better taking it out on the trip first and then getting it done once I'm back. I can ask the dealer, but I'm sure we all know what their answer will be!
Thanks to you both. I hope to read more responses from you and others before the trip.
Old 10-10-2011, 08:02 AM   #5
BirdmanQ5's Avatar
[QUOTE=ben_aip;24208789]Yes, only the front have low pads sensors. I did thought about getting aftermarket auto parts pads for the front just to make the trip, but not too sure if anyone carries these to fit our Q5. Will make a few calls on Tues, coz this is our Canadian Thanksgiving long weekend.
Happy Thanksgiving! About getting aftermarket pads, I wouldn't even bother. I got Hawk Performance Ceramics made specifically for the Q5, and so far haven't really enjoyed them (squeak when cold, still a good amt of dust compared to stock except the dust is brown not black).
BirdmanQ5's Build Thread
2011 Audi Q5 2.0T S-Line Ibis White w/ Pano Roof, Nav & Adv. Key
GIAC Stage 1 software : Adam's Rotors - Race Double Slot Silver Zinc : POSI-Quiet Semi-Metallic Pads
ECS Spacers F-17.5mm R-20mm : Hoen X11 Xenonmatch Fogs : LED Plate Lights : A2DP Streaming
Carbon Wrapped Trim : Vinyl Hood Stripe : Gloss Black Plate Frame : Black Rings
VAG-COM Mods
VIM : Winking DRL's : Ambers : Needle Sweep : Gear Display : DRL @ 15% : Backup Camera Disengage @ 20kph : Convenience Windows
BirdmanQ5 is offline   Reply With Quote
Old 10-10-2011, 12:15 PM   #6
ben_aip's Avatar
Quote:
Hi Birdman.
Thanks and Happy Thanksgiving to you too.
I have Centric Posi-Quiet & Power-slot Rotors on order from Autoanything.com. From fellow forum members who had swapped to these products, it seems they are very pleased with them, esp achieving a good balance on ultra low dust, noise and 'bite' effectiveness. Local dealers here don't yet know of Centric products, but had warned me against using Hawk Ceramics in particular on Audis, as most ended up swapping back out for OEMs...but that's what most dealers will tell you, on anything other than...
Old 10-11-2011, 07:07 AM   #7
gat821's Avatar
Going over the Rockies? Don't risk it, as others have mentioned, just grab some pads from the auto store. Peace of mind...
2011 Q5 3.2 Premium Plus, Navigation, B&O, Quartz Grey on Black.
2012 A4 Premium Plus, Navigation, B&O, Ice Silver on Black
gat821 is offline   Reply With Quote
Similar Threads
Thread Thread Starter Forum Replies Last Post
Brakes: Cost Pads Rotors ebod0000 A6 (C7 Platform) Discussion 104 Yesterday 06:59 PM
Audi A4 2002 S4 6spd 98k rsixxer23 Vehicles For Sale 4 01-06-2016 03:25 AM
88 quattro cs spring chicken looking for help DannyG123US Audi 5000 / 200 / V8 Discussion 4 09-07-2015 05:53 PM
:: ECS Tuning :: Assembled by ECS Audi B6 A4 1.8T Quattro Brake Service Kits. ECS Tuning-Audi A4 (B6 Platform) Discussion 0 09-02-2015 11:39 AM
Brake Sensor Confusion C6Silver Q7 Discussion 4 09-01-2015 08:46 PM
Tags
2010, a5, audi, brake, brakes, break, drive, front, light, pad, pads, q5, q7, s5, warnign, warning
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
