Carista app is now available for iOS, too :)
#12
#13
I'm looking for an explanation as someone who is unfamiliar with the concept, not for some Internet message board a$$hole response.
Thank you.
#14
To everyone else: Is there any kind of device that doesn't contain a counterfeit chip that would work? One that may be purchased at a brick and mortar store?
Thank you.
Thank you.
The answer is no. Your best bet, right now, are the ones for $30 on Amazon under the brand ikkegol.
#15
You got that answer because if there was anything you could buy at retail that worked it would have been mentioned. Carista themselves just said that there are no real ELM327 devices available.
#16
At this point we have something similar to this for the C7 platform: Customizations | Carista OBD2 - Vehicle Diagnostics and Customization
But we're actively adding functionality to that platform, as there are many other settings that we could support. Do you already have an ELM327-compatible device? If so, I'd love to get some technical data from your car, so we can add more customizations for that model. Btw, I didn't know the 2016 model year had come out already. Don't next-year models start production in May usually?
#17
#18
The 2016 model (refresh) is early to North America. The ROW calls it the 2015. In any case, this is the newer MIB-2 infotainment system, so I'm guessing some things have changed.
#19
I have an adapter. I do not have the car. It should be here in a week or two (currently stuck in Davisville, RI, as far as I know).
#20
Ah, I see, that makes sense. Well, if they kept the same BCM ("central electronics" module), then most settings should still apply (and Carista will automatically pick that up). But if they changed to a new module, you probably won't see more than just a few customizations. If the MMI is new, then we certainly won't have any settings for it yet. But we will try to update the app with support for the new modules in a timely fashion. When you get the car, please send us a "debug data" report, which will just read all current values and part numbers. Do this before changing anything with the app. Thanks! Actually, if you'd like, email us at support@caristaapp.com and we'll hook you up with free usage of the Pro features if you agree to help test the new settings on your car.
