Cruise control braking - AudiWorld Forums
Go Back   AudiWorld Forums > Audi Models > Audi Q3 /Q5 / Q7 > Q5/SQ5 Discussion
Log In
Q5/SQ5 Discussion Discussion forum for the Audi Q5 SUV
Sponsored by: Audi
LinkBack Thread Tools Search this Thread
Old 05-23-2014, 07:11 PM   #1
Highpark's Avatar
Default Cruise control braking
Going down a hill, if the cruise is on, it applies the brakes. I can't stand this. Is there a way to disable cruise control braking?
Highpark is offline   Reply With Quote
Old 05-23-2014, 08:38 PM   #2
AudiWorld Expert
Reggie's Avatar
I don't think it is applying brakes but rather engine braking alone.
Reggie is offline   Reply With Quote
Old 05-24-2014, 01:10 AM   #3
I have experienced this as well. I can't say with certainty that the brakes are applied, but it sure feels like it, and I have noticed the brake lights come on as well. No idea how to disable it, although that would defeat the purpose of having cruise control.
pacod is offline   Reply With Quote
Old 05-24-2014, 04:12 AM   #4
Brakes definately applied, you can see the brake lights go on at night. Would be nice to be able to turn that off with VCDS. I asked them years ago about it and they knew nothing about it back them. I toggle the cruise off on the downhills to save my brakes. Our 2008 does not apply the brakes.
2011 Q5 Ibis White 2.0T
2008 A4 Cabriolet Ibis White 2.0TQS
2000 A4 Laser Red 1.8TQM (sold)
rdA4WtQ5 is offline   Reply With Quote
Old 05-24-2014, 07:13 AM   #5
AudiWorld Expert
Reggie's Avatar
Quote:
Since I have a 011' mine may not come on.
Old 05-24-2014, 08:31 AM   #6
From the 2013 Owners Manual page 95, "the speed is kept constant by modifying engine power or through an active brake intervention".
2013 Q5 2.0t, Cuvee Silver/Black, Pano, 19", MMI/Nav, B&O, Advanced Key, 3M Crystalline.
2014 BMW 3281 X Drive, White Metallic/Tan, Nav, 3M Crystalline etc.
Q5 Bob is online now   Reply With Quote
Old 05-24-2014, 08:50 AM   #7
Senior Member
MP4.2+6.0's Avatar
Default It does use car's brakes; related aspects...
It uses the brakes too. My 2006 A8 w/ adaptive cruise is the same. So was my 2004 Toyota Sienna.
It will actually apply them fairly aggressively if another vehicle pulls into your lane in less than the pre set following distance. Or very rarely, on winding multilane freeways (like Interstate 80 in the CA Sierras) if it misreads a slow vehicle in a different lane as being in yours. Typically very good at tracking--better than my Toyota Sienna was--but in weird situations like changing radius curves it can't really perform the calculations correctly using a combination of the forward radar and the angle sensor. Where a curve tightens up it can misread a semi struggling up a grade in the tighter part of the curve in the slow/truck lane and can get on the brakes aggressively. Thus, a situation to avoid using it, or know the issue in sweeping multilane decreasing radius curves and be ready to disengage quickly or put foot on gas to override.
Meanwhile to OP's post, no known way I have heard of to turn off that element, nor have I seen that on other vehicles w/ adaptive. What I find you can do is to marginally bump the pre-set speed up if you want when coasting downhill, sometimes a few times, and then bring it back down once the downgrade is over. W/in the first few MPH of speed over the setting it doesn't immediately intervene w/ the brakes, and the added speed bump up timed correctly keeps it so without accelerating either. Once you do it a few times, you find the pattern w/out much hassle.
Current #1: '06 D3 A8L W12 brilliant black w/ amaretto; 4 seats, CPO; 275/35 on OEM polished + forged 20's; S8 sway bars (see: rear bar and gen'l D3 bar info and front bar); tweaked 385mm front factory brake mod and matching rear brake mod; matching C6 A6 back headrests (better rear view: headrest tweak); owner installed AMI retrofit with part number details here. [pics now only in picture poster] Upper control arm reference (+ more info in replies) here. Lower cost D3 OES sway bar links here.
Current #2: 2013 Q5 2.0T hybrid; Scuba blue w/ chestnut sport interior; Euro delivery 7/2013 (pictured at Ingolstadt); RS5 front brakes
"New" #3 at 3/16: 2015 CPO D4 S8, < 3200 miles at delivery. "All the options": Daytona Grey, Vermont Brown Exclusive full leather, B&O, Cold Weather, Night Vision, Driver Assistance Package, (std.) heads' up display, 21" 5 arm wheels
MP4.2+6.0 is offline   Reply With Quote
Old 05-24-2014, 11:03 AM   #8
Q-Branch's Avatar
I like the braking feature most of the time, but if I want to coast I just bump the cruise control stick forward to cancel and then pull it back to resume the cruise after I've coasted. The Q seems to be pretty forgiving with the resume speed, so I just resume the cruise within +/- 3 MPH of the set speed. I've driven a Toyota and a Buick that both go crazy if they aren't resumed on exactly the set speed. The Toyota would basically floor the accelerator if it was resumed from 1 MPH below the set speed.
2011 Q5 2.0T
Q-Branch is offline   Reply With Quote
Old 05-24-2014, 06:45 PM   #9
apohis's Avatar
I really dislike this "feature" and I hope someone figures out a way to disable it.
2012 Vespa LX150ie
apohis is offline   Reply With Quote
Old 05-25-2014, 06:53 AM   #10
You do realize that the purpose of cruise control is to control/maintain a single, driver determined speed, right? Well, gravity and going downhill tends to cause the vehicle to speed up, above that set speed. Brakes are the only way to fix that issue. If you're not on cruise control you can see the hill coming and lift in advance to maintain speed. I'm sure some day that sort of "smart car" will exist, but until then you're gonna have to either turn the CC off or raise the speed a bit on the hill to allow the car to coast and the computer not to see a speed that is out of the allowable range.
gtwagon941 is offline   Reply With Quote
Similar Threads
Thread Thread Starter Forum Replies Last Post
Audi A6 FS: 370mm Alcon / Stasis Front Big Brake Kit! Allroad BBK N'Syncro Parts For Sale 5 05-17-2016 09:59 AM
PARTING OUT 2002 A4 B6 1.8T Cmmartin23 Parts For Sale 25 05-08-2016 01:12 PM
New Owner! sirh A6 (C7 Platform) Discussion 7 09-16-2015 05:32 PM
First Experience with Audi Dealer Service Dept. the_duke A8 / S8 (D3 Platform) Discussion 6 09-10-2015 09:02 AM
Audi Other 2013 Audi RS5 (low mileage) $61,000 buiyahkah Vehicles For Sale 0 09-07-2015 09:29 AM
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
