Customize your Q5 (coding) through a mobile app!
#101
Don't think anything you can do will kill a warranty. Worse case scenario is the dealer will reset your options.
I'm just waiting for the iPhone version then I'll be grabbing it!
#102
AudiWorld Expert
Maybe you could be a little more clear. As stated, your response did not make much sense to most of us. Maybe you could provide a direct link to the post you are referring to?
Thanks.
I'm not trying to argumentative. But if more than one member has a problem determining what you meant, then there is probably room for improvement for the benefit of all of us.
Thanks.
#103
Thanks.
Thanks.
#104
I am happy to report that after a few attempts, and some good, albeit not timely support from Carista, as well as other Forum members, I now have ability to open and close my windows via the remote.
Turns out that I had to check "yes" to all the selections in the windows section.
Thanks Guys!
Thanks Guys!
*Ordered the upgrade to enable windows opening with remote
*Established communications with OBD adapter and Carista examined options available for my 2015 Audi SQ5
*Checked "yes" for enable windows opening and closing, and open window using remote, and they were saved
*Still nothing in MMI Central Locking about windows....???
#105
Thanks Guys!
Thanks Guys!
#106
I was also puzzled by the lack of remote window control, but in the base MMI system, after Carista has enabled this (and perhaps the car is restarted) a NEW MENU OPTION is added. You have to scroll down because it will be AFTER the first screen full of options. I think it was something like "Convenience" and it gave choices for opening and closing the windows and sunroof, including the choice of opening the sunroof or just tilting it open.
It isn't obvious at all, but in the car setup menus, there will be a new choice added.
If my dealer had had any brains, I'd have paid him to enable this but no, "Audi vill not let us do this! Nein!"
Thank you, Carista. Incorporate in Moldavia or Tahiti or something, label the software "For Adult Use Only" and let someone else argue about liability. Anything that weighs two tons and moves at a hundred miles an hour, probably needs adult supervision anyway.
#109
AudiWorld Expert
