Old 07-25-2016, 10:33 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Audi Q5 or Q7 Interior Guides
Print Wikipost
DIY: Cabin Air Filter Replacement
Old 02-13-2011, 02:11 PM
rs4-380's Avatar
Default DIY: Cabin Air Filter Replacement
Part of the 15k mile service is a new cabin air filter. It is very easy to do yourself.
Up in the passenger front footwell in front of the lower glovebox plastic there is a foam cover that is held on by 3 thumbscrews.
Remove the thumb screws and remove the foam panel, you will then see this.
You need to slide the white plastic cover to the right (passenger side of the car. If you can't get it to budge you can pinch the section in the middle with the two ridges that keep the cover locked in place.
To remove the cover fully you may need to pull out this foam piece behind the fan motor.
The filter just pulls out and a new one goes in the same way. You may have to contort it a bit to get it to bend, if you have floor mats it is easier to get it in with them removed.
When sliding the white cover back on make sure the filter is pushed all the way up into the housing or you may not be able to slide the cover fully closed (ie the ridges on the white cover need to be on the left side of the black housing).
Old 02-13-2011, 02:50 PM
gat821's Avatar
Excellent walkthrough! Thanks - pictures are always worth a thousand words. I wonder how much Audi charges for doing this at the dealer?
Old 04-08-2011, 04:36 PM
ookila's Avatar
very helpful...but since it is my first time.....took me like 30 minutes and my back hurts..hahaha...and my new filter seems kind loose..but over all it is good learning process....thank for the pictures and advices...
Old 05-14-2012, 05:29 PM
bigdadi's Avatar
http://www.youtube.com/watch?v=RO6-6KDeexE
Old 05-15-2012, 03:39 AM
CB17's Avatar
Thanks for posting!!! I will use this as a reference in the future.
agp2572
A4 (B9 Platform) Discussion
11
07-07-2021 04:30 AM
Prime Time
A4 (B8 Platform) Discussion
05-15-2014 12:58 PM
aty
S4 (B8 Platform) Discussion
05-08-2014 06:00 AM
rbrunner
Audi 100 / A6 (C4 Platform)
10-30-2007 09:26 AM
aspire a4
11-10-2001 06:03 PM
Quick Reply: DIY: Cabin Air Filter Replacement
