View Poll Results: How long did your original battery last ?
One Year
0%
Two Years
0%
Three Years
0%
Four Years
6.25%
Five Years
15.63%
Six Years
12.50%
Seven Years
34.38%
Eight or More Years
31.25%
Voters: 32. You may not vote on this poll
How long did your OEM battery last?
Old 01-23-2018, 03:42 PM
DennisMitchell's Avatar
Default How long did your OEM battery last?
If you have replaced your original battery, please vote on how long your battery lasted.
Old 01-24-2018, 06:08 AM
Bad Andy's Avatar
I’m still on my original battery. Car purchased new November 2009.
Old 01-24-2018, 06:45 AM
Wow. Wonder if lack of cold winters makes a difference for you.
Old 01-24-2018, 09:00 AM
deutschmick's Avatar
Delivered 3/27/10. Still on original battery.
Now I'm concerned!
Old 01-24-2018, 01:36 PM
MurrayA4's Avatar
Dennis can you add a choice "still on original" This will be an interesting pole to monitor.I'm impressed with my Varta.4th real Canadian winter and it still cranks over my 20:1 diesel at -35c as if it was a gasser.
Old 01-24-2018, 01:39 PM
farmerjones's Avatar
8 years later and 8 brutal winters later I decided to replace my batter as a precaution, LOL. I'm sure my experience is not typical but does prove batteries can last a long time. The exterior temp and driving cycle greatly impact the longevity of a battery, as well as where it is placed inside the car. However having a battery last 5 years should be a reasonable expectation and is probably typical.
Old 01-24-2018, 03:39 PM
shokhead's Avatar
just shy of 4 years.
Old 01-24-2018, 06:10 PM
AudiWorld Expert
Reggie's Avatar
Default I replaced my RS4 battery at 7 years just to be safe
I think Audi uses AGM batteries which last a long time. I have not looked at my battery yet on my new to me 2014 SQ5 but I expect the same. Many RS owners were seeing 10 years.
What kills batteries is heat. Putting the battery in between the double fire wall Audi used was great to reduce this issue. But putting them in the trunk was better. Going to AGM technology was even better.
What most people don't realize is that though heat kills batteries it takes cold weather to show it up because cold weather causes oil to thicken and metals to constrict causing friction to make the starter motor to need more Amps.
Old 01-24-2018, 07:19 PM
I can't modify the survey. But I am looking for replacements only because those still having original would distort the stats because of leases and trade Ins.
Thanks.
Old 01-25-2018, 02:35 AM
rez
rez's Avatar
Still on original battery. 2012 with just over 122,000 kms (76,000 miles). To say we have cold winters would be a bit of an understatement.
Quick Reply: How long did your OEM battery last?
