Drive select-can I adjust suspension? - AudiWorld Forums
Go Back   AudiWorld Forums > Audi Models > Audi Q3 /Q5 / Q7 > Q5/SQ5 Discussion
Log In
Q5/SQ5 Discussion Discussion forum for the Audi Q5 SUV
Sponsored by: Audi
LinkBack Thread Tools Search this Thread
Old 05-08-2014, 08:50 PM   #1
Default Drive select-can I adjust suspension?
We love our Q5 but the ride is a little stiff (combined with somewhat hard seats) on city streets. I wonder if drive select on Q5 would allow the suspension be made softer the standard Q5's suspension
thanks
2012 RX350 AWD NAV Premium
2010 Premium Plus Meteor Gray w/ B&O
2008 Land Rover LR2 (sold)
2005 Volvo XC90 (sold)
2003 Honda Pilot (sold)
m1964 is offline   Reply With Quote
Old 05-08-2014, 10:51 PM   #2
Senior Member
Default Which wheels do you have?
Simpler fix would just be to go down an inch on wheel size. For example if you have 19's, try 18's. Lots of OE 18's around at decent pricing from others who want to go the other way.
Current #1: '06 D3 A8L W12 brilliant black w/ amaretto; 4 seat setup, CPO; modestly lowered, H&R 20mm rear and 12mm front DRs with 275/35 on OEM polished + forged 20's; S8 sway bars (see: rear bar and gen'l D3 bar info and front bar); tweaked 385mm front factory brake mod and matching rear brake mod; matching C6 A6 back headrests (better rear view: headrest tweak); owner installed AMI retrofit with part number details here. [pics now only in picture poster] Upper control arm reference (+ more info in replies) here. Lower cost D3 OES sway bar links here.
Current #2: 2013 Q5 2.0T hybrid; Scuba blue w/ chestnut sport interior; Euro delivery 7/2013 (pictured at Ingolstadt); RS5 front brakes
Prior (each modded): 2000 C5 A6 4.2 & '96 C4 A6 2.8Q, both still w/ family; '85 C3 5000S 5 sp FWD; '73 C1 100LS
helpful cross reference to C6 MMI and various other TSB's that also cover D3 A8's.
MP4.2+6.0 is offline   Reply With Quote
Old 05-09-2014, 04:30 AM   #3
spijun's Avatar
Quote:
thanks
It is possible, but if you have adaptive damping suspension
http://forums.audiworld.com/showpost...6&postcount=18
Q5 2.0 TFSI,S-tronic,
Milano leather, B&O, 19" 5-arm polished
Excuse me for my English
spijun is offline   Reply With Quote
Old 05-09-2014, 07:53 AM   #4
gronk's Avatar
thanks
Also, take a look at your tire pressure (when cold). In the manual there are numbers for normal and max load, I personally found a significant difference in comfort between the 2 numbers. Moreover, when I got the car from the dealer the tires were way overinflated.
gronk is offline   Reply With Quote
Old 05-09-2014, 10:01 AM   #5
Xylar5's Avatar
If you have recently received your Q5, make sure that the tires were adjusted to factory. Our tire pressure was at 40 psi.
If you have the ADS system, changing to comfort will definitely make a difference (better) in the ride, even with 20" wheels.
2014 3.0T Q5 Monsoon S-Line+
Xylar5 is offline   Reply With Quote
Old 05-09-2014, 04:33 PM   #6
Quote:
I keep the pressure at 30 psi all around to keep the ride tolerable.
Old 05-09-2014, 04:35 PM   #7
I am thinking about it, but maybe 2015 model which is going to be Drive select+sports interior in one package.
After re-reading the post on reliability of 2010 3.2 Q5 I am inclined to keep ours for a little longer...
Similar Threads
Thread Thread Starter Forum Replies Last Post
Adaptive Air Suspension v/s Sport Adaptive Air Suspension Pmpsch Q7 MKII Discussion 14 12-06-2015 02:14 PM
MMI Car button Doesn't work 2004 audi a8l hellonwheels33 A8 / S8 (D3 Platform) Discussion 8 10-09-2015 12:29 PM
Audi Other S4 B6/B7 StaSis Motorsport (Ohlins) Suspension w8 Parts For Sale 1 09-23-2015 07:33 PM
When to replace shocks and struts - Wobble at 20mph/40mph ZPA117 A4 (B8 Platform) Discussion 4 09-08-2015 12:55 PM
Adjust passanger seat from driver side fkaufman A7 4 09-07-2015 08:59 PM
Trackbacks are On
Pingbacks are On
Refbacks are On
