:: ECS Tuning :: GEOMET® Coated Brake Rotors | Audi Q5 2.0T
Audiworld Basic Sponsor
ECS Tuning proudly offers an exclusive line of premium, corrosion-resistant rotors: GEOMET®.
GEOMET® is a special coating containing metal oxides, zinc, and aluminum flakes, sprayed over the entire rotor surface to ensure complete coverage, and baked on at 600 degrees to form a durable and attractive silver-gray finish that fights rust far better than paints or other conventional coatings.
You can expect your new GEOMET® rotors to outperform and outlast stock rotors, and look great behind your alloy wheels.
Braking That Lasts!
Click HERE to order or for more information
Fits:
Audi Q5 2.0T 2011+
Let me know if you have any questions.
Jason
The obvious question is: Do you recommend any particular pads with the new rotors and if so which and do you sell them?
How do these rotors stand up to the brake wiping feature? and to road salt and grit for those of us who live in the snowy parts of NA. Seen the video but it didn't look as if that test had temperature cycling as well as salt water.
We do not at the moment.
Brake pads are highly dependent on personal needs. You can use any pad on these rotors.
You can expect the same functionality from these rotors as OEM. The GEOMET holds up very well to salt and heat cycling. I run GEOMET slotted rotors on my personal vehicle and they have held up wonderfully through NE Ohio winters.
Jason
Jason
dmanikas
A4 (B7 Platform) Discussion
11-21-2005 01:57 PM
