If you haven't bought an oil dipstick yet...
#23
I would be careful with that one. The Audi service rep and tech showed me that one. It is NOT to be left in the car. The others available through ECS and EuropaParts are meant to be left in.
However, you are right in that it could be used by our TDI brethren (and sisters) on an as needed basis to tell if the MMI is lying.
#24
Same for the 3.2l and 3.0T. I have had both and left the dipsticks in all the time, no problems. When I got my first one I noticed the entire thing was plastic so there was some question about leaving it in the engine due to the heat. That was until I noticed that the tube itself is also plastic as is the filter housing. Must be some high temp stuff. Not the best engineering choice for these type of parts IMO but it works. Probably saved them a few grams in overall vehicle weight and of course, cheaper than metal.
#25
Got this. Dealership tech set the slider to the correct value for our 2015 Q5. Slider could be set for other Audi vehicles.
Sealey VS600ED Audi Engine Dipstick 600mm | eBay
#26
This may help. Post #10 from another Audi forum.
3.0 V6 TDI Dipstick - Audi A5 Forum & Audi S5 Forum
#27
#30
Dipstick dilemma update update... Need length of dipstick...
I just received my dipstick from ECS, I have a 2015 Q5TDI 3.0. The first dipstick from Eurosports was too short (17.5") from the bottom of the orange handle... Too short. The ECS dipstick AM version (yellow handle) seems too long in that the level of oil is above the max line, actually up to the bottom of the ball... Checked when oil was cold. This one is about 20" long. For anyone who has a Sealy adjustable dipstick, please provide me with the length that the dealer set for you for your Q5 TDI 3.0. Based on the picture posted it looks like it was set at 9.2. I need the length in inches from the tip to where the handle contacts the tube.. Want to verify if this one is the correct length. If it's not, I will send this back, use the MMI and hope that the sensor keeps working... What a hassle to find the answer to a very simple question... ECS would not guarantee that the Q7 3.0 TDI dipstick would work in a Q5 TDI, presumably the same engine... The Q7 folks on this forum have stated that this dipstick works. VERY confused...
