Interior light housing removal
Location: The "moderately less" corrupt state of Illinois
I'm pretty sure I saw a post here that provided pictures identifying how to remove / where to pry the interior lights so they can be swapped with LEDs, but I'll be darned if I can find it.
Specifically, I'm looking for a "how to" removal of the center cluster and the rear reading lights. I've got the LEDs, I just need some guidance removing these bits safely. Puddles, visor, trunk, and glove box are all done.
Can someone provide a link to the post if you've got it?
Thanks!
Thanks!
Thanks Spijun - that's exactly what I'm looking for -
Any chance you have that information for the cluster of sunroof switch, reading lights, interior light, right above the console for Q5's with a sunroof?
Footwells are LED already - you won't need to change them unless you're changing the color.
Trunk is super easy, just us a small screwdriver to pop up the end with a small cut out in the lens.
The driving lights are easiest changed following these instructions.
AudiEnthusiasts Change Driving lights
AudiWorld Expert
ECS has great videos for those of you who still need to do it.
Audi B8 A4 Quattro V6 3.2L Lighting Interior - B8S4LEDINT - Master LED Interior Lighting Kit - ES#2210291
Another thing is I changed all my interior lighting and when I get to the last one --- driver side visor. The light did not lit and even I put back the original light bulb, it stay off. Could that be a fuse issue or somewhere else is shorting out?
Thanks,
Phil
