Introducing the Carista OBD device!
#31
display the " Hidden Menu"
Question-- Once I activate the Hidden Menu with Carista( which I have) I read instructions to press and hold the " setup and car buttons" etc. Im not finding a " setup " button. Could it be the Menu and Car buttons?? or something else? HELP
#33
#35
So I also received my Carista ODB2 mid-week and changed a few settings via my Android phone (enabled gauge sweep and convenient windows) on my 2015 3.0T Q5.
However I noticed some settings were changed that I didn't select and I had to change back using the app.
Unlock doors via remote & Unlock doors via smart key (door handle button) both went from "ALL DOORS ON 1ST PRESS" to "DRIVER'S DOOR ON 1ST PRESS, ALL ON 2ND"
And Front footwell lights while driving & Rear footwell lights while driving both went to "ENABLED" from "DISABLED"
Has anyone else had that occur? Once I set back the next day they were fine and "sticking" but surprised that some items were changed that I never selected.
#36
Just received my Carista yesterday. Enabled gauge sweep and convenient windows on my Q5, and turned the "winking" feature off. The device and app work great!
I turned on the "Hidden Menu", but am unsure how to utilize it. I am most interested in the transmission gear selector. The links indicated above seam to apply to a VAG Com device and not necessarily the "Hidden Menu".
About the door lock settings: that seems weird as well. It shouldn't change as well, unless something was changed in the MMI.
If non of this explains the situation or you know that it is not the case, write us an email (support@caristaapp.com) or reply here.
#37
Just did some settings via the Carista..worked perfectly and very easy..
Any plans to create a setting to disable the 'passenger airbag off' light on the dash?
#39
Hidden Menu
Can someone please give a step by step instruction on how to access the Hidden menu? I have enabled it with Carista but am unable to figure out how to proceed from there. And what does" restart required" entail? Thoughts???
#40
http://www.audizine.com/forum/showth...ft-2013-B8-5-s
