Jack pad for SQ5
Old 11-20-2014, 07:04 AM
  #11
stash64's Avatar
My Q5 has been on the dealer's lift and there is no damage to the pinch welds... I would be pissed if there was. Not sure about the Q5, but my A3 definitely had pads specifically for the 4-point hydraulic lifts and using those pads for lifting would in no way damage the pinch welds. And the jack Audi provided for the A3 was designed to straddle the pinch weld... so again no damage to the weld joint. I disagree that rolling over the weld joint is acceptable.
Old 11-20-2014, 09:27 AM
  #12
luv2golf's Avatar
Originally Posted by Yoshimura
I would like to get a jack pad... Anyone knows if the Protech Sidelift Jack Pad works well with the SQ5?
Have you considered using a hockey puck (its what I use), they are quite plentiful and easily found here in Canada
Old 11-22-2014, 01:12 PM
  #13
billyg's Avatar
I second the hockey puck. Been using one for years, worked great.
Old 11-22-2014, 01:23 PM
  #14
AudiWorld Expert
ex-quattro PETE's Avatar
How does a hockey puck help you get over the pinch weld?
Old 11-22-2014, 05:38 PM
  #15
stash64's Avatar
You have to cut a slot in the puck.
Old 11-24-2014, 03:47 AM
  #16
Jazzy's Avatar
Concur -- this is what I did and works a treat.
Old 11-24-2014, 08:10 AM
  #17
cobrar97's Avatar
I notched a piece of softer wood, and it works perfectly. I'll have to give the hockey puck a try, just because I know it won't split or break in the future.
Old 12-04-2014, 12:07 PM
  #18
182 Driver's Avatar
I use a hockey puck on top of my floor jack.
Old 12-05-2014, 10:37 AM
  #19
AlbertaBound's Avatar
I also use a notched out hockey puck. Works great, and is really inexpensive.
Old 12-05-2014, 10:43 AM
  #20
SJGQ5's Avatar
Originally Posted by ex-quattro PETE
Hmm... I have one of these that I used on my old A4 many years ago. I was hoping I could also use it on the Q5, but I haven't even checked yet what the lift points look like...
Amazon.com: Floor Jack Saddle Adapter for Rocker Panel Pinch Weld: Automotive
I use this on my Lexus and it works great..
Quick Reply: Jack pad for SQ5
