Just want to share my suspension install
Old 08-10-2015, 07:36 AM
  #21
BrooklynSQ5's Avatar
Very nice! What a great stance now!
Old 08-10-2015, 08:48 AM
  #22
nivlek's Avatar
Sweet! more pictures please!
Are you running any spacers? Any rubbing under load?
Old 08-10-2015, 11:15 AM
  #23
Imola wagon's Avatar
yes I have spacers 12.5/20
no rubbing so far.
Old 08-10-2015, 11:49 AM
  #24
yakev724's Avatar
What sway bar are you going with?
Any idea if the Macan S/Turbo one will fit? Might be a nice OEM upgrade.
Old 08-10-2015, 12:10 PM
  #25
USS swaybar. there is not much option.
Old 08-28-2015, 07:38 AM
  #26
GlacierSQ5's Avatar
Nice setup and it looks good the SQ is lowered. I just took mine in for the H&R Coilover along with SPC camber arms. I should get the truck back this weekend and will post pics!
Old 08-28-2015, 01:54 PM
  #27
nivlek's Avatar
Any further review on handling and ride quality? I just bought the H&R -3 springs, so tempted to hit the buy button on the Bilstein shocks.
Old 08-28-2015, 02:48 PM
  #28
Default 1200 road trip update.
OK. here is my 1200 mile update in no-cal to so-cal and back review.
Installed on car as of this update.
Bilstein B8 sport Strut (First time using the B8 sport, I have been using PSS9/10 on all my other cars, totally different feel.)
H&R -3
034 Tran mount
034 x-brace
034 rear diff
ECS spacer
OEM 21' wheel w/ p-zero w/ 9k miles on it.
AWE exhaust.
... It is FREAKING good.... I really don't know whether to say "hard" or "stiff" It is softer than stock SQ5 suspension, in a way. with OEM, i could feel ever crack on the road. Now, that is gone. It is planted to the road. it absorb. and absorb.
Handling in turns is another story. OK the car still leans. I and don't have swaybar right now. I thought I can get away without it. But IT IS NEEDED.
Low speed turn leans a lot more than mid/high speed. and that is Bilstein nature. At high speed on-ramp. it holds very well. The faster I go, the tighter it gets.
The rebound is excellent. it is not bouncy over speed bumps. it reacts fast.
Overall, normal driving, much more comfortable than OEM.
Once thing I notice , the car itself now , steering is much more sensitive . and after 2 alignment. it is not perfect. though the alignment print out shows it is perfect. everything is in the green.
overall will I recommend it. Yes.
more update once I get swaybar install.
excuse my ESL....
Old 08-28-2015, 08:38 PM
  #29
nivlek's Avatar
H&R -3
034 Tran mount
034 x-brace
034 rear diff
ECS spacer
AWE exhaust.
excuse my ESL....
Thanks for the review! Sounds positive! I am a fan of bilstein for dd, have B8+eibach on my mini and it definitely improves both handling and ride quality over stock, also on my 911 PSS9 made the car more flat but still with acceptable comfort.
I believe its the 034 x-brace that made steering is much more sensitive? but not the suspension?
Old 08-31-2015, 08:25 AM
  #30
GlacierSQ5's Avatar
Ok, I am just going to post my pics here since I don't feel like to start a new post. Here's the H&R Coilover set up with about 2.5-2.7" lowered all around. I got the front camber arms install so alignment was good. However, there rear left is really negative. Anyone else have this problem? Do you think I should get another alignment or I need a set of camber arms/bolts to fix this problem?
The ride feels much firmer and less floaty. Since it has the 21 incher, I feel all the bumps at speed.
His little sibling
Quick Reply: Just want to share my suspension install
