MMI favorites in nav
Old 04-28-2014, 12:03 PM
Mrchntmarine's Avatar
Default MMI favorites in nav
So I've seen a post or 2 on this and wanted to see if more people are experiencing this and what's "normal". With my phone paired and blue toothed I have entered some favorites in the nav. I have also entered some with no phone blue toothed. So one day while out driving I went to my favorites to pull one up and it wasn't there and then i blue toothed the phone and the destination reappeared. Audi N America says that I should be able to see all favorites all the time regardless of whether a phone is blue toothed or not - but that's not my experience. What about others here - can you all see your favorites all the time, blue toothed or not? I can find nothing in the manual that states favorites visible are dictated/visible while the system is in the same mode as when they were entered. Heck, it even allows me to have 2 separate and different address entered under the home address icon - I have one address entered while blue toothed and a different entered while not blue toothed!!
Old 04-28-2014, 12:17 PM
HOiYA's Avatar
I read on another thread if you add an entry while there is no Bluetooth connection, then the entry will always be available. If you add an entry while a phone is paired via Bluetooth, it will only be available when the same phone is paired.
I've seen similar behavior but paired to a specific key. That way each driver can have their own settings and entries in the NAV.
Old 04-28-2014, 12:29 PM
Originally Posted by HOiYA
I read on another thread if add an entry while there is no Bluetooth connection then the entry will always available. If you add an entry while a phone is paired via Bluetooth, it will only be available when the same phone is paired.
I've seen similar but paired to a specific key. That way each driver can have their own settings and entries in the NAV.
i think that may be the same post I saw. So I guess that if I want to always see my favorites, whether I have my phone on me or not, I should turn off my blue tooth before entering favorites… Sounds like a silly process to me. Wonder what they were thinking?
Old 08-13-2014, 12:36 PM
Default TSB 2036575
I'm pretty sure someone answered this issue in the thread, but I wanted to share what I received a few days ago. Couldn't remember if there is a special place for posting TSB's
File Type: pdf
Old 08-13-2014, 01:17 PM
laakness's Avatar
Thanks for sharing, that is good info.
User 71423
Q5/SQ5 MKI (8R) Discussion
04-07-2017 02:16 PM
Sci-fi_Wasabi
12-11-2012 09:58 PM
coop3302
Telematics Discussion
05-18-2006 04:08 PM
Matt1474
01-26-2006 05:39 PM
Bluto
10-23-2002 05:01 AM
Quick Reply: MMI favorites in nav
