Is there supposed to be so much negative camber at the rear wheels?
Old 05-25-2014, 02:38 PM
SQive's Avatar
Default Is there supposed to be so much negative camber at the rear wheels?
I now have 950 miles on my SQ5, and loving every single drive! When my wife drove away in it the other day, I saw very noticeably that there was a lot of negative camber at the rear wheels. I told the dealership about it on my "second delivery," and they assured me that it is normal.
Okay, first let me say that I do have experience in running a tire shop and performing alignments as well as years of hobby performance work. I understand the benefits and drawbacks of each of the alignment adjustments. I no longer have access to that fancy equipment, but I did measure a difference of 1.1 inches between the top and bottom of the rim. Negative camber at the rear helps in cornering, but unless it's a teenager's slammed Honda, I don't think it should be that readily noticeable. It will also cause considerably more wear on these freakin' expensive 21-inch tires.
My question for this post to other SQ5 owners: Do you have the same amount of negative camber at your rear wheels?
Spijun...you have those official specs?
Old 05-25-2014, 03:23 PM
Yoshimura's Avatar
1.3 degree according to this thread.
https://www.audiworld.com/forums/sho....php?t=2797522
Old 05-25-2014, 03:29 PM
Transfer's Avatar
I agree the rear camber is noticeable to the trained eye. I don't know what the specs are, but I like it.
Dalancroft's Avatar
I've noticed the same on my wife's 2011 Porsche 911 Carrera S. I haven't measured it, so not sure if it's 1.1 inches like yours, but seems reasonable in a full-on sports car that is expected to go very fast and flat through turns.
Old 05-25-2014, 04:59 PM
SQive's Avatar
It may very well be correct. Negative camber is a performance setting found on cafe racers and the like. I've just never noticed one so much at the stock settings. Sometimes the shape of the rear end makes it appear more pronounced.
So..."Does this camber make my *** look big?"
Old 05-25-2014, 10:08 PM
spijun's Avatar
These are the official specifications
Engineers and experts from Audi are so have decided, I do not understand why argue about something you have no influence.
Surely there is a reason why it is so
Old 05-25-2014, 10:27 PM
SQive's Avatar
What?
I mean...WHAT???
Old 05-25-2014, 10:53 PM
spijun's Avatar
What?
I mean...WHAT???
What to do now . Make as you like
When you change the camber at the rear wheels, let us know
Here's instructions:
Old 05-26-2014, 01:58 PM
Dalancroft's Avatar
What?
I mean...WHAT???
For the record, sp, I understood exactly what you meant.
sethroid
Q7 MK 1 Discussion
03-18-2016 06:48 AM
Shawn99/30V
Q5/SQ5 MKI (8R) Discussion
01-02-2011 12:50 PM
S4 2004
12-27-2004 07:52 AM
trojansruleucla
05-11-2002 06:39 AM
EPS
02-28-1999 04:53 PM
Quick Reply: Is there supposed to be so much negative camber at the rear wheels?
