Need help from tech guys
#21
This is why I ask questions here. I found more useful information than with my "friendly" dealer!
Thanks a lot guys for your help!
#24
I will check that over the week-end.
However as the pump is all made of plastic (with the exception of the rotor/stator) I fail to see how corrosion could result in a short to ground. My guess is that the pump has a bit of a hard time to start during cold weather, drawing too much current so the ECU thinks it is a short to ground, resulting in the fault.
In your other post where you detected the error code and cleared it. You said once you cleared it, the error cam back almost immediately. Did this happen when the engine was cold, and when it was warmed up?
Also right now it is working fine since they cleaned the contacts, this doesn't seem to be poorly performing motor, even when loaded at cold.
Again, clean the terminals, coat them with silicone grease, and run until it fails again. It could last forever.
Is this the pump?
Looks easy to remove and replace.
#25
Since I came back from the dealer it was working fine, it stopped working today. I just reset it.
Sunday I will lift my car and clean the connectors.
But I believe it is more the pump that is at fault. However I don't see any amperage reading in the fault details. To me this is a bit puzzling.
And thank you for the picture. This is the correct pump.
#26
Doesn't sound like a connector problem....
It happened right away the first time and the next morning the second time. First time the engine was warm, second time it was cold.
The A/C controller controls this pump. I'm sure that there is a measure block in VCDS that indicates the current flow to the pump, I sure don't know which one it is, maybe someone around here does?
#27
Pump circuit diagram......
since it threw the error again and the pump stopped working. It's odd that you need to clear the error code to have the pump start again. That is very strange, unless it goes into to some limp home mode that needs to be reset .
Looks like the A/C controller is direct, no relay to the pump, but the circuit does go through 2 intermediate connectors (again they would be ok, or be shorted, not intermittent)
Keep us posted.
#28
I will try to put a relay tomorow between the pump and the A/C controller. This way if for any reason the pump draws too much current at start, the fault will not occur. I will put a fuse on the wire that will connect to the pump. This way if the current is really that high, it will blow... and I will order a new pump.
This is a low tech solution... It reminds me of my younger days where I could spend hours messing around in my "good old" K car!
I hope it will help me get to the bottom of this!
Thanks for you help
#29
Thanks for the schematic.
Thanks for you help
Thanks for you help
Good luck!
#30
I will try to put a relay tomorow between the pump and the A/C controller. This way if for any reason the pump draws too much current at start, the fault will not occur. I will put a fuse on the wire that will connect to the pump. This way if the current is really that high, if it will blow... and I will order a new pump.
Thanks for you help
Thanks for you help
The relay didn't work. I get the same fault all the time now. This was far fetched and I didn't really think it would work.
However since the relay was connected, I did some tests. I placed a 8 amp fuse to drive my pump. This circuit connected directly to the battery is driving my pump via the relay. The pump always work when I trig the relay and there I doesn't seem to draw too much current (My meter amp tester is dead...).
Since it is -14C outside, I decided to manually drive my pump for now. I connected the relay trigger to the fog lamp. Since the pump is behind the passenger's side fog lamp (and not on the driver's side as the schematics were showing), it was an easy connection. So now, I only need to turn on the fog lights... Or turn right as the turning fog lights feature is activated on my car to get warm air.
This will do until I order a new pump... Hoping that a new pump will fix the issue permanently.
Oh! One last thing. My dealer told me that they could reproduce the fault when disconnecting the pump... Guess what, when you do so you do not get the same error at all! Gee I love my dealer!
Short to ground fault:
01020 - Water Pump (V36)
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 4
Fault Frequency: 2
Reset counter: 202
Mileage: 137395 km
Time Indication: 0
Date: 2015.01.31
Time: 12:43:29
Freeze Frame:
Voltage: 14.30 V
Temperature: 64.0°C
Current: 0.000 A
Voltage: 0.00 V
Voltage: 0.63 V
Bin. Bits: 00000000
RPM: 1960 /min
Load: 1.3 %
Disconnected pump fault:
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 4
Fault Frequency: 1
Reset counter: 205
Mileage: 137574 km
Time Indication: 0
Date: 2015.02.01
Time: 20:42:22
Freeze Frame:
Voltage: 14.40 V
Temperature: 66.0°C
Current: 0.000 A
Voltage: 2.10 V
Voltage: 0.63 V
Bin. Bits: 00000000
RPM: 680 /min
Load: 1.3 %
