Permanently Disable "Service Due" Light
#31
This is what would make sense:
When the seat sensor detects a minimum weight, activate the airbag.
The driver can manually disable the airbag for various situations, like a piece of furniture, or a bag, or a dog crate, in the seat.
Whenever the auto activation is overridden (whether the seat is empty or not), light the indicator.
From my reading of the regulations above, this should be perfectly in line with the requirements.
I suspect Audi's decision to have it reflect to auto activation rather than override is based a desire to be able to visually confirm that the airbag is enabled with a passenger in the seat and make it less likely a car is driven around for an extended period with a defective seat sensor. (And hence a disabled pass. airbag.)
#32
You need the VCDS to recode a "battery" replacement
I'm still perplexed how this design issue could be deemed acceptable by anyone. If Audi does not disclose to buyers (before the purchase) that they will be unable to perform routine service without a trip to an Audi dealer (along with written proof of service) to reset the service light, then in those cases Audi should provide owners the necessary equipment or fix the design defect.
Many DIY tasks will require a VCDS.
#33
#34
#35
I understand the the VCDS is third-party equipment (not Audi equipment). The computer or phone needed to run the VCDS would also have to be third-party equipment (not Audi equipment). Therefore, in order to own and maintain an Audi, you have to purchase specialized third-party equipment, but there is no guarantee that such third-party equipment will continue to be available since the manufacturer of such equipment is free to discontinue it any time for any reason. Hypothethecially speaking, what would an Audi owner do if that happens?
#36
Gannym you've called this a "defect" once again.
So I'll ask you once again, how in Hades do you define this as a "defect" ?
I can't see how any definition of "defect" applies to the behavior of the reminders in the car.
Please, do enlightmen me. Surely I'm not the only one who can't find any "defect" here.
#37
Ok, let me enlighten! A "design defect" exists when a defect is inherent in the design of the product itself. Here, not being able to perform basic maintenance (e.g., change oil, replace battery, replace brake pads, etc.) without specialized third-party equipment, when it could have easily been designed so as to not require that specialized third-party equipment (like other vehicles, including BMWs), is a design defect.
#38
Best solution for you - buy a BMW which is without design defect
I do not understand what you really want.
You're buying a car based on whether you can permanently disable the "Service Due" light or because how looks a car, ride quality, workmanship, reliability
#39
While it's true there's no guarantee that any company would not go out of business, Ross-Tech has been around for many years and provides cable upgrade paths and software/firmware updates. If the cable or software becomes outmoded with a new car or to accommodate evolving computer operating systems, they support it. Really not much different if one was to worry that Audi, Apple, Google or any other company would go out of business.
#40
Ganny is sort of right on this subject.
