Post facelift European Spec Tail Lights Coding for Q5 & Part Numbers:
#21
Does anyone happen to know the codes for US spec taillights? I used the codes OP mentioned however like @jcutchall mentioned the brake lights and signals were reversed. I didn't spend a lot of time trying to figure patterns in the codes. I haven't decided whether to get euro-spec taillights at this time but would like to change the way current taillights work.
Thanks.
Thanks.
#22
Sir,
Think this link will answer your question...if not just let me know
https://www.audiworld.com/forums/q5-...ights-2884188/
V/r
Dan
V/r
Dan
#23
Sir,
V/r
Dan
V/r
Dan
Ethan
#24
Guys, need some help here. I received my ROW (amber) tail lights, but prior to installing, I coded with VCDS to ensure it would work with my US spec lights prior to installing, no issues at all.
With the EU/ROW tail lights, I just popped open the little connectors, took out the pins and swapped the connectors over. Plugged in the lights, and the behavior was reversed. So, I figured there must be something in the lights that need to be coded. So, I used VCDS, recoded back to US, then back to the changes mentioned in the thread(s), using TEST before SAVE, still not working.
Any thoughts/suggestions?
#26
Ok... Not a problem. I'm curious though, from a coding perspective, do we know what each bit is in each of those channels? If not, is there a way to find out?
#29
Jay,
Try this...is what I did to make my wife's car work.
Channel--- Code
195--------- 5
196--------- 37
197--------- 12
198--------- 44
Not sure if this will fix your problem, but worth a try....just make sure you make good notes, encase it doesn't.
V/r
Dan
Channel--- Code
195--------- 5
196--------- 37
197--------- 12
198--------- 44
V/r
Dan
IgorRRR (09-18-2022)
#30
Well, I did some troubleshooting today. I used my digital multimeter and checked the pins for blinker and brake lights. I swapped the pins for each and it's working fine now. I must have inadvertently swapped the pins, or, the pins on the ROW and US tail lights are in fact swapped. Dunno, but it's working now, so yay. 8-)
Has anyone said anything about the brightness difference between the full red LED and the single row of amber LEDs?
