Premium Gasoline Required? - AudiWorld Forums
Go Back   AudiWorld Forums > Audi Models > Audi Q3 /Q5 / Q7 > Q5/SQ5 Discussion
Log In
Q5/SQ5 Discussion Discussion forum for the Audi Q5 SUV
Sponsored by: Audi
LinkBack Thread Tools Search this Thread
Old 10-13-2010, 04:26 PM   #1
Default Premium Gasoline Required?
Is premium gasoline a requirement or a suggestion for the Q5?
Will I harm my engine or cause "knocking" if I use lower grade gasoline?
Has anyone driven their Q5 with lower grade gasoline and not experienced any problems?
I know someone who has used only 87 octane gasoline for their A4 and has had no problems whatsoever.
NMW1982 is offline   Reply With Quote
Old 10-13-2010, 05:05 PM   #2
soonerfan's Avatar
There is a lot of info on the subject in the Forum archives if you care to search. Audi recommends premium fuel. One can use a lesser RON fuel, but it is not recommended. The ECU will adjust to a certain extent on timing, etc. but you will not achieve the MPG or the performance that the highest grade of fuel you can buy will give you. For the few extra dollars you spend for Premium Grade fuel, be it 93 or 91 octane (US) the benefits of increased mileage, response and peace of mind is worth it, and may be a push, dollar to dollar. Here in Oklahoma we have the luxury of being able to buy 100% gasoline and are not forced to buy an ethanol blend of any %. One can feel the difference in the seat of one's pants and mileage.......not to mention no degradation of seals, fuel lines, etc.
2014 Q5 TDI P+, Ibis White/Black
S-Line Plus Pkg., Sport Pkg,. MMI Nav Plus, B&O, Side Assist, Tow Hitch, Protection Pkg.
Gone but not forgotten:Two B5 A4's and a 2011 Q5 P+ 2.0TFSI
soonerfan is offline   Reply With Quote
Old 10-13-2010, 05:34 PM   #3
FitzLA's Avatar
On my first Q5, I used premium and then switched to middle. Never noticed a difference, even on fuel economy. And what you would save in fuel economy by using premium, you would spend in the difference in price. Negligible difference. I've only used middle grade on my '10 Q5, and it's been completely fine.
2010 Q5 Meteor Gray/Black 3.2 Premium Plus with Nav Package and 19" wheels
2009 Q5 Black/Cardamom Beige 3.2 Premium Plus with Nav Package SOLD
FitzLA is offline   Reply With Quote
Old 10-13-2010, 06:10 PM   #4
Audi recommends 91 and up. You can use 87 with reduced engine performance. Anything below that and Audi says you can wreck your engine. A manufacturer recommends something for a reason and I dont' think Audi is in bed with the oil companies. In a 40K+ car, I don't see the point of trying to save a buck by going with a lower grade but to each his own.
2010 Q5 Garnet Red/Cardamom Beige Prem Plus w/ Nav
hmn4858 is offline   Reply With Quote
Old 10-14-2010, 06:17 AM   #5
Quote:
I dont understand why people use mid grade, its only 10 cents difference, you only save a $1.50 on a fill up.
The G Man is offline   Reply With Quote
Old 10-14-2010, 06:27 AM   #6
all modern vehicles have knock sensors that will pull timing to compensate for lower grade fuels. Running 87 will NOT ruin your engine. What it will do is reduce peak power output and reduce gas mileage.
12 Q7 3.0T, 09 R8, 09 3.0T Avant
rs4-380 is offline   Reply With Quote
Old 10-14-2010, 07:24 AM   #7
Huey52's Avatar
Exactly.
Quote:
Huey52 is offline   Reply With Quote
Old 10-14-2010, 09:14 AM   #8
kleinbus's Avatar
I have used 91 all the time.
What is this fuel price drama? You guys buy 40k car, complain about few pennies and barely drive the car anyways...
kleinbus is offline   Reply With Quote
Old 10-14-2010, 09:36 AM   #9
FitzLA's Avatar
Quote:
Because I don't see a difference in performance or fuel economy, and I don't really care. I lease my cars and get new ones every 1-2 years, so I'm not worried about long term, if it even has an effect. The $$ is not the point. I just don't see a use for it. The only thing I do care about, if the brand. I only use Shell or Chevron.
Old 10-14-2010, 10:16 AM   #10
You dont think that constant slight knocking and retardation of timing will hurt an engine over time? This cycle happens over and over again when using the low octane gas. At the very least, timing retartdation will create a incomplete burn cycle, this will cause carbon build up, especially in direct injection engines.
Similar Threads
Thread Thread Starter Forum Replies Last Post
:: ECS Tuning :: NEW!! B8 S5 3.0T ECS Performance Lightweight Flywheel ECS Tuning-Audi Audi A5 / S5 / RS5 Coupe & Cabrio 3 02-04-2016 09:36 AM
:: ECS Tuning :: NEW!! B8 S4 ECS Performance Lightweight Flywheel ECS Tuning-Audi S4 (B8 Platform) Discussion 1 02-04-2016 09:30 AM
ChipWerke module for S4 tonalvoltage S4 (B8 Platform) Discussion 2 10-22-2015 08:11 PM
2016 SQ5 SoFla S4 Q5/SQ5 Discussion 8 10-09-2015 07:21 PM
Shelby Monsoon Enough (break-in and other questions) Monsoonenough S4 (B8 Platform) Discussion 3 10-03-2015 03:59 PM
Tags
2010, a4, angeles, audi, brand, gas, gasoline, los, needed, octane, octone, premium, q5, q7, required, requirement, selling, stations, watered
Trackbacks are On
Pingbacks are On
Refbacks are On
