Q5 adaptive brake lights?
So I have a 2011 Q5. I used the VAGCOM to enable adaptive brake lights. Do these only work when doing hard stopping from speed or also at rest? Thanks
Enable Adaptive brake lights
[46 - Comfort System]
[Coding - 07] -> Long Coding Helper -> Byte 8
Bit 0 Emergency Brake Flashing via Turn Lights active Enable bit 1 = active
Bit 1 Emergency Brake Flashing via Brake Lights active Enable bit 1 = active
Thanks, will try over the weekend.....
The adaptive brake lights setting is very similar, but it does require a panic stop from high speed to activate this on our Audi's. It doesn't make them flash at low speeds, but does give people behind you additional warning when you are quickly reducing speed. Hopefully his will reduce rear end collisions.
Hope this helps.
Eric5412
08-17-2011 08:15 PM
