Q5 V6 Diesel Vs Gas Engine
#11
Q5 2.0 P+ is 42,200.00 base
For the 5,300.00 difference you get the potential for towing up to 4400 lbs., kick-*** acceleration, great mileage and range, better resale at the end and all of that made it work for me.
I don't give a rats behind if I spend a few more bucks over the ownership span of the vehicle for driving diesel.
Bottom line: the Q5TDI is a fantastic package.
#12
Q5 TDI P+ is 47,500.00 base
3.0TFSI Premium Plus = $45,400
3.0TDI Premium Plus = $47,500
#13
It's my first diesel, and am very happy that I chose it. I have been using Power Service Diesel Clean (6-7 oz/tankful) as suggested on this forum. I now have 6,700 miles on my 15 Q5 TDI, and it has exceeded my every expectation.
Still getting used to the tach reading so low, so much bottom-end torque, no high revs required...1,100 rpm at 60 mph in S8... A totally different beast when you put it into S!!
#15
All that plus the TDI has probably the best engine in the Q series for normal driving conditions, unless you are racing Vin Desile in the quarter mile, the desile is going to give you better performance around town then the v6.
#16
The question was the gas v6 vs. The TDI. That is only at $2100 difference. With the price of deisle where it is now, a driver who logs avg miles on their car should make up that difference in about 2.5 years. Not to mention the avg resale of a desile is about 10% better than gas. Which makes up the difference and then some the moment you drive off the lot.
#17
The OP did not specify a V6 gas engine, just a "gas engine". Not to pick nits on the subject. For my money, I think the Q5TDI might be the best package Audi produces for the US market because it is so versatile and hits all the high marks: range capability, mpg, handling, towing, acceleration, safety and luxury. I've owned both the 2.0TFSI and now the 3.0TDI and I can assure you that the TDI is worth every red cent over the 2.0 TFSI.
I did test drive the 2.0 engine and while it was smooth, the power just wasn't there for me. It was OK, but i had my doubts over whether it would be able to pull its weight over time. I have the same feeling when driving the 2.0 A4 as well...hit the peddle and wait...I think I have been spoiled by the torque in the TDI.
#18
Originally Posted by spijun;24708962[B
]How is the difference $8k ?????[/B]
Compare the same engine displacement 3.0TFSI vs 3.0TDI
$40, 900 2.0
So $7,200, i'll be more precise next time
#20
Ultra 93 is $2.80
.21 a gallon difference, and it's even less of a difference going to costco for 91.
Regarding resale being 10% higher on resale, I'm not seeing that locally, and considering that the cost of the TDI is ~ 5% more on initial purchase, it still doesn't make this a slam dunk financially.
The 2.0 and TDI will both tow 4400 lbs. so that's a wash.
Better MPG? it's a wash if most of your driving is not on highway (which is the case in most of the North East)
Better acceleration? The TDI is half a second faster to 70. Slight tip to TDI, but half a second? that's a wash unless you're racing
TDI weighs more by 400lbs
I currently own an X5 35D, and I've owned a 2.0T 2012 Q5, and buying another, so I have some experience with diesel and the 2.0t, and I'm not bashing either side.
The bottom line is that it's not a slam dunk on which engine package is better, different scenarios will dictate.
