Q5 vs QX70/50
#21
Good reply thanks.
I agree on the street the torque is just fun, numbers aside, it is not slow and feels like an old school big block in the city when you stomp it. That is all that mattered combined with better gas mpg. I have always put 100k on my cars before I see them and none them at 100k have been nice usually radiator tranny issues engine leaks etc which isnt cheap.
So what major maint is required on a diesel? I know people at well over 100 like 150k-200k start to talk about things like cleaning out the fuel rails,injectors etc. but otherwise there is no plugs wires dizzy etc. Just change oil and fuel filter every 5k? 10k?
Of course AC,radiator are same on both cars correct? hit or miss either way.
Like other diesels in truck, people add chip and bigger down pipes for huge gains is that the same for the TDI? or will it sound like a truck then and smoke? will it start to sound like a truck after 60k miles.
#22
My wife's 2004 Golf TDI sounds like a truck, but it pretty much always has (especially in drive-throughs). It'll occasionally have a tiny puff of black if she really gets on it, but it's nothing like what I've seen come out of trucks (or cars with exhaust trouble for that matter).
#23
What is the DPF? what does it cost to replace at 120k?
What does a fuel filter & oil change out every 20k cost?
The down pipe comes straight off the turbo doesn't it? what is downstream of that, DPF?
Sound wise once broken in the TDI shouldn't turn into a f150 diesel sounding truck should remain the same?
Are muffler systems available help give it a throaty performance sound?
#24
DPF = diesel particulate filter, it's what traps particulate matter prior to exhaust so it's not emitted into the air. Not sure what the replacement cost is once it's time. Some random comments on the internet say "very", but what that actually is, I'm not sure. Supposedly you can clean DPFs to help prolong the life of the filter itself, but how that compares, I'm not sure either.
I'm on Audi Care for now, but my 15K was going to be around $600 at my dealer (costs will vary based on labor rates at the least). I don't know what the breakdown was for the particular components of the service, though, to say what the fuel filter replacement cost would be.
Not sure as to the exhaust system's precise layout, but the DPF is mid-stream with the urea injection after that. DPF's probably the most restrictive part of the system, so the only gains you'd probably see would be modifications after that point. But I don't tend to follow exhaust performance so I'm out of the loop there anyway.
