Quattro and tires
#11
AudiWorld Expert
That's a pretty graphic, but not very informative if you really think about it. Where can I read about some actual independent test methodology and more quantifiable results behind this graph?
What is the definition of "Performance" in the above graph? What does 0% Performance Level mean?
Don't get me wrong. I don't advise anyone to drive on summer tires during winter, but everything is not as black and white as that graph would make you believe.
#12
AudiWorld Expert
Winter tires actually have very good grip during summer too because their rubber becomes even softer, and soft rubber = grippy rubber. The only issue is they wear out very quickly.
Again, I see the point the graph is trying to convey, but they dumbed it down so much for the layman that it hurts my brain a little.
#13
Maybe you know something better than hundreds of engineers working in the tire industry
Good luck
https://www.audiworld.com/forums/q5-.../#post24474677
#14
AudiWorld Expert
I'm just asking for clarification. Can you provide it? The graph is too generic to be of value to someone who knows a little more about tires than an average Joe. That's all I'm saying.
#15
We typically have some cold days, but very little ice or snow. We will be sticking with the OEM Bridgestone summer tires.
Luckily my wife's office shuts down most of the time when there is ice, so she keeps her little unit at all toasty at home in the garage.
I have tested various rubber products with pressure at temps below 40F, and there is a very noticeable change. I have had to change my test setup and procedure to get things to work.
#16
My summers will work fine on a dry road in 20 degree weather. you're right. but add some rain to the mix when it's 35 degrees and see how your traction is. just feel how hard and greasy the compound becomes.
tell me how wonderful your traction is when you need it and you dont have it.
#17
The cold weather compounds in winter tires cause them to be too sticky in the warmer conditions. I have found that on a warm late fall day or spring day when I have my winter tires on my car's handling is worse because the tires are too sticky. I expect a certain amount of slip and that it is progressive and controllable. With the wrong tire for the conditions I find myself unable to predict when the tire will let go. Ultimately it's up to you, but that's how I justify the annual switch to winter tires.
#19
Thanks for all the responses. So, getting the impression I should definitely put the regular 18s back on for winter
BOOO... UGLY WHEELS.
Thanks y'all
Thanks y'all
Audi Q7 2009 Q7 S-LINE, $22,500
Buckwheat2088
09-12-2015 07:01 AM
xkahn
New Member Welcome Area
09-05-2015 06:20 PM
mkirkpatrick
Wheels & Tires Discussion
09-03-2015 08:31 AM
ECS Tuning-Audi
09-02-2015 11:39 AM
Al_Bundy
09-02-2015 07:24 AM
