Rear light out 1st day back from body shop
So today I got my Q5 back after it had been hit in my parking lot, while parked. The body shop put on a new bumper, and refinished the rear quarter panel, I picked it up at 5pm and when I was pulling it my driveway a dummy light went on saying the rear light was out. The seems like quite the coincidence, is this the body shops fault? Could of they messed something up with the wiring, causing it to blow a light? I need to call Audi and the body shop and get this resolved, any advise would be greatly appreciated! Thank you!
Collisions often damage incandescent lamp filaments. In this case it seems likely that a connector was not attached correctly. The rear lamps in the bumper are incandescent bulbs. Often you can tap on the lens and they light again with the broken filament welding itself together for a little while anyway. You could play dumb and ask why the bulb wasn't replaced.
Bob,
I just spoke with the body shop, they want me to bring it by. However, are body shops qualified to work on a newer Audi? This is my 3rd Audi, and one thing I do know, is that the wiring and electronics are highly sensitive.. Also, I looked for a light out last night, and could not find a light out. Why is the warning light going on, but no light actually out?
Thanks for your input.
Bob,
https://i.imgur.com/sVBGqvc.mp4
Good Luck and report back with your findings.
Bob
Bob,
When the hatch is opened the lighting switches from your hatch to your bumper. Close your hatch it switches back to your hatch.
The bulb monitor system works if the light is turned on or not but not always right away.
Turn on your lights and open your hatch. You should now see the light that is out.
I got it, it was the 921 little light on the very end, was very blown.. burnt to a crisp. All is good, I appreciate the advise, I would have never found that screw, I knew taking the entire bumper off to change a light bulb sounded ludicrous.
morobluecab
11-09-2006 08:50 AM
rookie18
09-04-2003 03:09 PM
Stu B
10-23-2000 08:05 PM
GAP
09-14-1999 06:46 PM
