Rear wents not blowing?
I found for the rear vents, they only seem to work if you have air blowing out the front dash vents. If they are blowing out of those particular vents, then air is also flowing out of the rear vents. If you have it in auto then usually nothing is coming out of the rears. If you manually set the fronts to blow out of the dash (middle) vents, then you shoul feel air coming out of the back ones.
To try and make this easy, first you have to pick the vents you want it to use. Hit the button that looks like a person sitting with arrows pointing at them. Then turn the temp control **** until you see all arrows lit up. Next hit the fan button, and then turn the number up to 12. You should now feel air coming out of your back vents. Let me know if this helps
W12BTW
04-06-2019 09:33 AM
PBPhantom
A6 (C7 Platform) Discussion
13
06-13-2014 08:38 AM
