front door panel help
so, whilst getting clear film at a facility in the next state, the tinter apparently pulled the door panel out a bit to work with the front window tint i asked to have installed and when i got the car back, there is a gap now between the tweeter sail panel and the top of the door card and also a sizeable gap from there vertically down along the metal of the door. it's as if it's not clipped in or something but i can't see anything and it won't snap or anything when pushing it closer to the door. it looks like there is some sort of adhesive strip that seals the door card against the metal of the door and that is not even touching.
the driver side is tight and appears correct.
any idea what could be happening here? i was thinking a clip is not snapped in or even worse, that it's out of its spot in the card and fastened in the door without the corresponding anchor point on the panel.
the people who did this are too far away to worry about getting in touch with them for a solution so i'm on my own.
thanks, that's what i'm thinking. i'll dig into it a bit tomorrow and see.
and i tried to edit the first post but i guess there is a time limit on edits here. i meant to say that the passenger side is tight and correct.
huwla
06-22-2004 07:00 AM
