Rolling back VCDS codes by log file
Old 05-31-2014, 06:59 AM
Oudimon's Avatar
Default Rolling back VCDS codes by log file
I searched and looked through the ross tech stuff but.....Is there a way to load an old log file to put the coding back to what it was??????
Old 05-31-2014, 07:45 AM
spijun's Avatar
Yes
C:\ROSS-TECH\VCDS\Debug
- CodingLog.TXT ----- for coding
- AdpLog.TXT ------for adaptation chanel
Old 05-31-2014, 08:32 AM
MP4.2+6.0's Avatar
Default IIRC, you may need to be at same version of VCDS software...
as when the earlier changes were made, or the files get lost if not separately copied. Otherwise, yes they are a good trail of documentation of prior tweaks.
Continued note to self: step 1 before modding a new vehicle--make a baseline copy of the entire scan w/ all the module codings and don't assume I'll just "remember." BTDT.
Old 06-01-2014, 04:02 AM
Oudimon's Avatar
I prescanned before coding a few minor things with no errors. Afterwards....
Monday,26,May,2014,17:21:04:03240
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.2.0 (x64)
Data version: 20140212
VIN: WA1LFAFP0DA038683 License Plate:
Mileage: 63640km-39544mi Repair Order:
Chassis Type: FP (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 36 42 44 46 47 52 53 56 5F 62
6C 6D 72
VIN: WA1LFAFP0DA038683 Mileage: 63640km/39544miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (DET-CPMA) Labels: None
Part No SW: 8R1 907 115 B HW: 8K2 907 115 L
Component: 2.0l R4/4V TF H09 0005
Revision: ECH09---
Coding: 6A2A0013242600062000
Shop #: WSC 37931 000 1048576
ASAM Dataset: EV_ECM20TFS0118R1907115B 001006
ROD: EV_ECM20TFS0118R1907115B.rod
VCID: 3467D0809F37C7BE4FF-8061
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans (J217) Labels: 0BK-927-156.clb
Part No SW: 8R1 927 158 C HW: 0BK 927 156 AL
Component: 0BK 20TFSIUSA H16 1002
Revision: --H16---
Coding: 000002
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_TCMAL551211 002020
ROD: EV_TCMAL551211_AU48.rod
VCID: 3E73F2A8A17B1DEEA9B-806B
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 8R0 907 379 AK HW: 8R0 907 379 AK
Component: ESP8 quattro H09 0080
Revision: -------- Serial number: --------------
Coding: 151D18
Shop #: WSC 06335 000 00000
VCID: 8919D17420356A564C9-80DC
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 GP HW: 8K0 907 064 FP
Component: BCM2 2.0 H11 0621
Revision: 00002001
Coding: 0D854000000000000000
VCID: 8407C0400717373E3FF-80D1
Subsystem 1 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Component: J764 ELV MLB H40 0046
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8K1 820 043 T HW: 8K1 820 043 T
Component: KLIMA 3 ZONEN H04 0121
Revision: C1000000 Serial number: 01071120122432
Coding: 6481208000
VCID: 3979E1B4B0553AD69C9-806C
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 DH HW: 8K0 907 063 DH
Component: BCM1 1.0 H16 0103
Revision: 08016001 Serial number: 00000510234402
Coding: 26000091C13CAFC00000480300003D0D0F1C4608A209022100 0008004000030100000034000000
VCID: 78FF24B0CBDFE3DEA37-802D
Subsystem 1 - Part No SW: 8R1 955 119 A HW: 8R1 955 119 Labels: 1KX-955-119.CLB
Component: WWS416 121030 H11 0050
Coding: 01DD13
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B
Component: G397_RLFS H06 0002
Coding: 02005C
Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Component: E1 - LDS H03 0031
Subsystem 4 - Part No SW: 4G0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0030
Subsystem 5 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H03 0003
1 Fault Found:
01771 - Control Module for Headlight Range (J431)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 27
Mileage: 63484 km
Time Indication: 0
Date: 2014.05.20
Time: 18:04:19
In this area I just changed fog cornering lights. I changed it back to normal and still an error : (
Old 06-01-2014, 04:40 AM
Oudimon's Avatar
I got it. Changed coding back, erased faults...good now..Wil reverse it for troubleshooting later just to make sure.....
Old 06-01-2014, 04:52 AM
spijun's Avatar
When you make a change, did you have deleted the old errors ??
Module for headlight range has nothing to do with fog lights
Old 06-01-2014, 07:47 AM
Bob Petruska's Avatar
Default Did you manually enter the old codes?
Or is there a way to have the txt file/VCDS restore them automatically?
Old 06-01-2014, 09:18 AM
MP4.2+6.0's Avatar
Default It's all manual
The files are just archival in nature. You basically need to compare the prior against the current side by side at the detailed coding level (up to the 32 digits/characters for some modules) and try to spot faithfully the changes.
Old 06-01-2014, 09:20 AM
MP4.2+6.0's Avatar
Default Can you be more specific on what the issue was?
From one reply it sounds like it may have been around the cornering light feature. Was that it? And if so, do you already have adaptive HID's? Any other change that came up as problematic?
NotoriousGLU
06-27-2017 06:40 PM
jnins5
VAG-COM Discussion
11-08-2016 11:26 AM
Redaudifor
01-07-2006 04:37 PM
ex-a8drifter
01-07-2006 01:43 PM
OPTIMUS PRlME
9
01-23-2004 08:30 AM
Quick Reply: Rolling back VCDS codes by log file
