Rough first shift
AudiWorld Expert
Rough first shift
On a cold engine, that first shift from 1st to 2nd gear is always pretty rough in our Q5. It appears the trans is holding the rpms higher and then violently slams into 2nd. It only happens once. All subsequent 1st to 2nd shifts and all other shifts are fine. And it only happens when the car wasn't driven for hours.
Is this a cause for concern or do they all do this? Currently at 3K miles.
I can't use the word 'violent' but mine's similar with your scenario.
I've adjusted because I know its' behavior. I'm easier on the pedal initially and don't push it until things warm up. And it's much milder when I start out in 'S' mode.
Also, for mine, the 'turbo lag' type behavior only occurs when cold...
Mine does this too. Didn't happen last year, but started doing it this year.
Last year in the cold id get a whining noise, this year its gone and switched to a jerky shift. Go figure.
AudiWorld Expert
Funny thing is on ours it actually shifts smoother when you give it more gas. Alas, since the engine/trans is cold right after a start, I typically baby it by giving it very little gas, and that's when this abrupt 1st to 2nd is most noticeable. Weird.
AudiWorld Expert
My experience with my 2014 is exactly the same. I still hate this transmission. The dual clutch tranny is on my Audi wishlist, hopefully in the near future.
