Secret Green Menu
Old 08-27-2016, 05:18 PM
  #11
chobi's Avatar
I just played today with carista customization and green menu.
I activated Lap timer and oil temperature in dashboard, battery level(green menu)
Ambient Lighting Control activated, I don't know how to activate VIM(video in motion)
Needle sweep activated. I disabled service interval I don't know if it will work (I am the one who is checking my car). I'll do more testing tomorrow.
Old 08-27-2016, 05:26 PM
  #12
chobi's Avatar
Originally Posted by ex-quattro PETE
Does this one show battery voltage somewhere in the dashboard?
No, you have to go in car menu and select battery level
Old 08-27-2016, 06:22 PM
  #13
AudiWorld Expert
ex-quattro PETE's Avatar
Thanks!
Old 08-28-2016, 06:42 AM
  #14
HZ60's Avatar
How to enable battery level Audi MMI 3G (A1 A4 A5 A6 A7 A8 Q3 Q5 Q7) - YouTube
This is the only VCDS tweak I could not get to work on my new Q. I did all the green menu settings - nothing. I found a VCDS setting in Module 5F - Byte 10 - Bit 2 that has a checkbox for " menu battery active" That didn't do it either. Looks like whatever MMI software I have in my 2016 won't allow this anymore, it worked ok on my 2013. Anyone figure this out?
Old 08-30-2016, 06:37 AM
  #15
AudiWorld Expert
Silly question, but before you can bring up the secret green menu using MENU+CAR buttons, do you need to enable it somewhere first, like through VCDS or Carista?
Old 08-30-2016, 06:44 AM
  #16
HZ60's Avatar
Enable Hidden Menu
[5F – Information Elect] > [Adaptation - 10] > Channel 6 > Change Stored Value From 0 to 1
Menu + Car = Enter Menu
Return + Car = Exit Menu
Menu + Center Control + Top Right = Re-Set MMI
Old 08-30-2016, 06:54 AM
  #17
AudiWorld Expert
Thanks. It looks like Carista can enable it, too.
Old 08-30-2016, 11:45 AM
  #18
chobi's Avatar
Yes Pete, in Carista there is an option
Hidden menu in dash screen via holding CAR + SETUP (req. restart)
ENABLED / DISABLED
Old 08-30-2016, 03:45 PM
  #19
MurrayA4's Avatar
Before you waste your time I'm pretty confident in stating that as of 2014 the battery meter was no longer available for activation.I've done many of the VCDS tweeks using the Ross-Tech cable,which I hope you all realize is one of Audi's major advantages over the competition.Got a Bimmer or MB or Volvo forgataboutit,go to your friendly local dealer !
Old 08-30-2016, 04:38 PM
  #20
AudiWorld Expert
Yup. You're right. It does not work on my 2015.
Quick Reply: Secret Green Menu
