SQ5 w/ 21s - road noise and ride quality?
Hi all,
I picked up a new SQ5 last weekend with the 21" wheels, upgrading from a 2012 Q5 s-line prestige. While I expected a stiffer ride and a bit more road noise due to the Sports suspension and tires, it's a huge change. The ride is not what I'd expect from a $60k vehicle. Even on "smooth" pavement I can feel the car bouncing at even the slightest imperfection. The ride feels more like that of a Prius Taxi cab vs. my 2012.
My dealer is telling me it's just the stiffer ride of the S but I'm thinking I need to stay on them to investigate further. There's also a noticeable cabin vibration when idling that they're claiming is normal.
Are others experiencing the same thing?
Thanks!
Thanks!
AudiWorld Expert
Did you not test drive one before buying it???
Anyway, first thing to check is tire pressure and see if it's not overinflated. They come overinflated from the factory, and the dealer is supposed to let some air out when they prep it, but sometimes they forget. And use the half-load PSI values, not the full load, unless you frequently ride with 4 passengers and a full trunk.
Second of all, read the reviews of the particular tires that came on your SQ5. Some of them are known for being extra harsh/stiff. You could try replacing them with another tire model that is more on the comfy side, but there is only so much you can do with short sidewalls, I'm afraid.
I'll check on the tires, and if it keeps being really bad I might try the 20s.
I did test drive it, but only so much I could glean from 45 minute drive on the highway and unfamiliar roads. I'm also wondering if something has been knocked out of alignment already.
I'm going to try and drive another SQ5 at the dealer to compare since the ride doesn't match the reviews I had read and experienced in my test drive.
What tires?
Our '15 came with Pirelli's and the car is dead silent.
As far as the ride much better than the '14 SQ5 we test drove and much quieter.
I was more than satisfied compared to what I thought we were getting.
My '14 has the Dunlop Sportmax 21". The ride is obviously not as comfortable as a standard Q5 but I did not expect that from the sportiest model. Road noise is no more than any other car I've owned. The ride on the highway is smooth so I tend to agree with others either the pressure is way too high or they forgot to remove the shipping blocks or something.
I'd say the dealer should address the issues, whether actual or perceived. It's part of good customer service. If they can't/won't then escalate it as necessary. Don't be pushed around or made to feel "dumb".
With that said:
What tires does it have? If they are RFT/Run Flats, then that will explain the poor ride. If there's no spare wheel, likely it has RFT's.
Tires are a HUGE factor. Want the smoothest riding sport tires? Michelin Pilot Super Sports. So smooth I'm getting rid of mine. Going with Vredestein Vorti's.
Most Audi sport models have excessively stiff shocks. Our A4 is still firm after 130K miles. But it's good. On other Audi's I have put on upgraded shocks and in ever7 case the ride is better and handling remains excellent (or better).
The shocks and tires are THE main factors for ride quality. Audi suspension systems are the best in the business otherwise. Every time I drive a BMW, and reminded of that, and others.
Hi all,
Thanks!
Thanks!
This being said, if you do go with 20" you have a few things going for you 1. More tire choices, Michelin PSS are a LOT quieter than Pirellis, 2. Higher sidewall, 3. Lower tire pressure for the same load.
I'm not into moding cars, but perhaps if you lowered yours you could go with a suspension setup that is less stiff as well. From what I can see it seems people are going the other direction though.
