Permanently Disable "Service Due" Light
Old 04-03-2014, 10:26 AM
Ganny's Avatar
Default Permanently Disable "Service Due" Light
so that it never returns. Can this be done by an Audi dealer? I don't have any interest in returning to the Audi dealer every 10,000miles for them to reset it. Also, since this light can not be reset by the owner without special equipment, and since the owner is under no obligation to either have service performed at an Audi dealer or buy this special equipment, shouldn't this issue be considered a vehicle defect for which Audi is responsible for rectifying?
Ganny is offline
Old 04-03-2014, 11:39 AM
uberwgn's Avatar
Ganny, welcome aboard!
Originally Posted by Ganny
...shouldn't this issue be considered a vehicle defect for which Audi is responsible for rectifying?
You're going to try to hold someone "at fault" for providing a service reminder
I've re-programmed my service and oil change reminders a bit using the VCDS interface. I don't know if you could change the service interval to 9999 days, for example. The system may not accept it. Find you local VCDS person and have them try.
uberwgn is offline
Old 04-03-2014, 11:46 AM
Ganny's Avatar
Thanks!
Yes, I find it to be a major defect that the service reminder can not be reset in the MMI (just like the oil change reminder).
I performed the 15,000 service DIY, and just dropped off my Q5 at the Audi Dealer to perform some unrelated warranty work. I asked them to reset the service reminder-they said they would if I provide "proof" that the service was performed. When I return to pick up my Q5, I will provide them receipts for the oil, filter, etc. and a signed receipt stating I performed the service, but if possible I want them to do a permanent (or close to permanent) disabling of the reminder. If they are unable, I might have to take up this "defect" with Audi corporate!
Ganny is offline
Old 04-03-2014, 11:59 AM
Transfer's Avatar
I will likely DIY as well or at least go to an indie shop. Is there really no way for the owner to reset the service reminder via some button presses or something?
Transfer is offline
Xenonista's Avatar
Why bother? The Ross-Tech VCDS cable and software license is only $350 and pretty much mandatory for any DIY work. If for no other reason than run a full scan once in a while to look for problems.
Xenonista is offline
Old 04-03-2014, 12:20 PM
Ganny's Avatar
Doesn't that cable and software require a PC? I have no interest in buying a PC and a Cable just to reset a service due light. I'm not sure what other DIY work would be precluded without the VCDS, but if I do need a VCDS to perform that other DIY work then I would also have the same objection (the functionality to do ordinary maintenance and repairs should be built-in).
Ganny is offline
Old 04-03-2014, 12:38 PM
NABS4's Avatar
Then you're SOL.
NABS4 is offline
Old 04-03-2014, 01:39 PM
Transfer's Avatar
Yeah this is pretty messed up if you can't reset it on your own. I plan to DIY maintenance or take it to an indie shop. There is no reason to pay dealer prices.
Transfer is offline
Old 04-03-2014, 02:05 PM
NABS4's Avatar
Then I'd strongly recommend the VAGCOM cable. If you're a DIY'er, it's worth the money, and it can easily be sold when you sell the call, or kept for your next VAG vehicle.
NABS4 is offline
Old 04-03-2014, 03:09 PM
Ganny's Avatar
I'm still perplexed how this design issue could be deemed acceptable by anyone. If Audi does not disclose to buyers (before the purchase) that they will be unable to perform routine service without a trip to an Audi dealer (along with written proof of service) to reset the service light, then in those cases Audi should provide owners the necessary equipment or fix the design defect.
Ganny is offline
Quick Reply: Permanently Disable "Service Due" Light
